What is the Relationship Between Logarithms and Progressions in Mathematics?
The discussion revolves around the relationships between logarithms and various types of progressions in mathematics, specifically focusing on harmonic, arithmetic, and geometric progressions. The original poster presents a problem that involves deriving a relationship involving logarithms based on given progressions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the implications of the relationships between the different types of progressions and logarithmic expressions. There are attempts to derive specific logarithmic relationships based on the properties of the progressions mentioned in the original statement.
Some participants are seeking clarification on the specific expression that results from the logarithmic relationship, while others are providing insights into how the choice of base x affects the outcome. The discussion is ongoing with various interpretations being explored.
There is a focus on the conditions under which the logarithmic expressions are valid, particularly regarding the choice of the base x and its implications. The original problem statement includes specific constraints and relationships that are under examination.
utkarshakash
Read this passage and then answer the questions that follow
We know that, if [itex]a_1,a_2,...,a_n[/itex] are in Harmonic Progression, then [itex]\frac{1}{a_1},\frac{1}{a_2}...,\frac{1}{a_n},[/itex] are in Arithmetic Progression and vice versa. If [itex]a_1,a_2,...,a_n[/itex] are in Arithmetic Progression with common difference d, then for any b(>0), the numbers [itex]b^{a_1},b^{a_2},b^{a_3},...,b^{a_n}[/itex] are in Geometric Progression with common ratio r, then for any base b(b>0), [itex]log_b a_1,log_b a_2,...,log_b a_n[/itex] are in Arithmetic Progression with common difference [itex]log_b r[/itex]
Q.1. Given a Geometric Progression and an Arithmetic Progression with positive terms [itex]a,a_1,a_2,...,a_n[/itex] and [itex]b, b_1, b_2,....,b_n[/itex]. The common ratio of the Geometric Progression is different from 1. Then there exists [itex]x \in R^+[/itex], such that [itex]log_x a_n-log_x a[/itex] is equal to
Let the common ratio of the given Geometric Progression be r.
[itex]r= \left( \frac{a_n}{a} \right) ^{1/n}[/itex]
Now from the last statement of the passage I can deduce that
For [itex]x \in R^+ \\<br /> log_x a, log_x a_1,...,log_x a_n[/itex]
is in Arithmetic Progression with common difference (D) = [itex]log_x \left( \frac{a_n}{a} \right)^{1/n}[/itex]
Let the common difference of the given Arithmetic Progression(not the above one) be d.
[itex]d= \dfrac{b_n - b}{n}[/itex]
Now from the second statement of the passage I can deduce that
For [itex]x \in R^+ \\<br /> x^b, x^{b_1},...,x^{b_n}[/itex]
is in Geometric Progression with common ratio (R) = [itex]x^{\frac{b_n - b}{n}}[/itex]
I have to find [itex]log_x \dfrac{a_n}{a} \\<br /> <br /> nlogD=log_x \dfrac{a_n}{a}\\<br /> <br /> n=\dfrac{logx}{logR} (b_n - b)[/itex]
Substituting the value of n from above into nlogD I get
[itex]\dfrac{logx}{logR} (b_n - b) logD[/itex]
Such that [itex]log_x a_n-log_x a[/itex] is equal to what?
That's what I have to find.
In terms of what?
Millennial said:
In terms of what?
OK I am giving you the options
a)a-b
b)[itex]a_n -b[/itex]
c)[itex]b_n - b[/itex]
d)[itex]a_n - b_n[/itex]
Depending on your choice of x, you can make it equal to a lot of things. To be more precise:
[tex]\log_x(a_n)-\log_x(a)=\frac{\log(a_n)-\log(a)}{\log(x)}=\frac{\log(a_n/a)}{\log(x)}[/tex]
Also, the restriction [itex]x>0[/itex] has no implications because [itex]\log(0)[/itex] is already undefined.
