New Reply
Factors affecting speed of travelling waves along a cable
Share Thread Thread Tools
Nov24-12, 04:08 PM   #1
I have a question concerning the speed of propagation of a travelling wave along a cable. If I have a cable and I move one end in a direction perpendicular to that of the length of the cable, it will generate a wave/pulse which will propagate along the cable with some speed. I imagine this speed depends on a number of properties of the cable: tension, elasticity, stiffness, density and also perhaps the viscosity of the fluid that the cable is resting in.
I can't, however, seem to find a formula to describe the speed of wave propagation based on these factors - has this been determined and can anyone point me in the right direction?
To give you some context, the cable Im concerned with is a cable in a biological sample. I've observed the propagation of waves of velocity along the cable and was hoping that extracting their speed could give me some insight into the properties of the biological tissue.
Thanks for any help!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Nov24-12, 05:58 PM   #2
Recognitions:
Gold Membership Gold Member
'Waves on Strings" is what you should look up.
Here's one link.
Nov25-12, 05:42 AM   #3
Thanks - that definitely gives more search results than waves on cables - so I find that velocity = sqrt(tension/linear density) but this doesn't take into account stiffness & plasticity of the string or the viscosity of the surrounding medium. I'm wondering if this is because with a typical tethered string in air all of these values are negligible and they approximate them to zero. Alternatively perhaps these values don't play a role in the velocity of propagation, only in the level of damping...
Can anyone help me out further on that?
Nov25-12, 06:04 AM   #4
Recognitions:
This is quite a lot harder and not the 'ideal case'. The modulus of the medium would definitely contribute to the velocity and it would be hard to find the relationships involved.
Is there any particular reason why you want to use a cable in this way for your measurement? I would have thought that there would be easier alternative approaches which would involve a simpler basic arrangement with fewer variables - what about observing a standing compression wave in a container with the sample in it. That could give you the speed of propagation which. along with the would then give the modulus. Attenuation would give you the losses.
A rigid cylinder with an actuator one end and various loads the other end would do the job, in some circs. But of course, it's the specifics of your system that need to drive your choice.
New Reply
Tags
cable, tension, travelling wave, viscosity
Thread Tools
Similar Threads for: Factors affecting speed of travelling waves along a cable
Thread Forum Replies
PhD Duration and affecting factors Academic Guidance 5
Factors Affecting Friction Lab Introductory Physics Homework 1
factors affecting heat exchange Classical Physics 4
Factors affecting the spring constant Classical Physics 2
Factors affecting performance of Antacids Biology, Chemistry & Other Homework 0
