Solve for trig equation with 2 variables
  • Thread starter Thread starter sunnybrooke
    Trig Variables
The discussion revolves around solving a trigonometric equation involving two variables, specifically focusing on the values that the expression 2 sin(3x) can take and how these relate to the variable k. Participants explore the implications of the sine function's range and its transformations.
  • Participants discuss the range of values for k based on the sine function's properties and consider the number of solutions for different k values. There are questions about the correctness of proposed solutions and the implications of k being outside the range of -2 to 2.
The discussion is active, with participants providing insights and questioning each other's reasoning. Some guidance has been offered regarding the relationship between k and the number of solutions, and there is an ongoing exploration of whether the problem can be approached algebraically without graphical methods.
Participants note the importance of considering the behavior of the function when k exceeds the amplitude limits of the sine function, specifically when k > 2 or k < -2, which may lead to no solutions.
sunnybrooke
I can solve the first part of the question. -2 ≤ k ≤ 2 because -1 ≤ sin(x) ≤ 1. How do I solve the second part of the question? Thanks.
Forget k for a moment, and think about what values 2 sin(3x) can assume. For each such value v, you have 2 sin(3x) = v, or 2 sin(3x) + (-v) = 0. So your k values are the same as the values of -v.
It may help to think about the graph of this function. It may even help to graph it. The 2 will increase the amplitude of the function and the 3 will scale the function. More specifically, it will "shrink" the function in the x direction (but it will not affect affect the amplitude). So from 0 to pi, the function will go completely up and down once and then be halfway done with a cycle. If you draw a horizontal line through this equation, how many solutions are there? (Hint: it depends on where the line is).
http://www4c.wolframalpha.com/Calculate/MSP/MSP4251a45574034148cah00001164cg2h50a94c78?MSPStoreType=image/gif&s=5&w=300&h=183&cdf=RangeControl
So if k:
is = -2, there will be 2 zeros
is between (-2,0] there will be 4 zeros
is between (0,2), there will be 2 zeros
is = 2, there will be 1 zero
Is that correct? Thanks.
So if k:
That looks correct to me, but you should check your result by looking at a graph of the function, perhaps with k=0 if you haven't already done so.
One other small matter, which you probably take for granted, but you should still mention if this is a homework or exam problem: what happens when k > 2 or k < -2?
So if k:
Very close. However, the only time that there are 4 solutions is when k=0. For k (-2,0), there are 3 solutions
There are never only 3 solutions. For -2 < k < 0 just consider k = -1 and test x = π/18, 5π/18, 13π/18, 17π/18.
Oops! Then what he said was correct
You're right, I forgot to mention that. When k > 2 or k < 2, there are no solutions (because the amplitude is 2).
Additionally, could I approach this problem algebraically (without referring to a graph)?
Thanks.
Never mind. Thank you Michael & piercebeatz.
  • · Replies 26 ·
