Can a Mono-Molecular Blade Separate Material?
  • Thread starter Thread starter d3mm
    Material
The discussion revolves around the concept of a "mono-molecular blade" and its potential to separate materials at a molecular level. Participants explore theoretical implications, material interactions, and the mechanics of such a blade, with a focus on its edge being a single molecule thick.
  • Exploratory, Conceptual clarification, Debate/contested
  • One participant questions whether a molecule-thick blade could separate material without causing damage, suggesting it might pass between atoms without affecting them if not forced apart sufficiently.
  • Another participant argues that if the blade can penetrate a material, it must be separating atomic bonds, implying some level of damage must occur.
  • A different viewpoint clarifies that it is the edge of the blade that is mono-molecular, proposing that the rest of the blade would need to be strong enough to rip apart bonds, with the mono-molecular edge acting as a fine wedge to initiate cutting.
  • One participant expresses agreement with the wedge theory, indicating familiarity with similar concepts in science fiction.
Participants express differing views on the mechanics of how a mono-molecular blade would interact with materials, with no consensus reached on the extent of damage or the effectiveness of the blade's design.
Assumptions about material strength and the nature of atomic bonds are not fully explored, and the discussion relies on speculative reasoning regarding the blade's functionality.
d3mm
Would a "molecule thick" blade separate material by enough distance to damage it?
I don't know if this should be in general physics.
In science fiction the concept of a "mono-molecular blade" exists, this being a blade with an edge that it the thickness of a single molecule, or thinner.
Ignoring considerations of material strength, would this blade actually do anything? I had the idea that a very thin blade might pass between atoms and leave them unaffected if they were not forced apart far enough to affect their atomic bonds?
Since no one else answered i would say if it can get through it separated the bonds, and though it may or may not cause much damage it did something. other wise people could walk through walls
I believe it is the EDGE of the blade that is monomolecular, not the whole blade itself, so I would assume the rest of the blade would rip apart the bonds if the blade itself was strong enough. The monomolecular edge functions as a very fine "wedge" to start the process I believe. An edge that isn't monomolecular can't get "between" the molecules/atoms of the material it's trying to go through, so you have to apply a lot more force to start cutting.
I THINK that's how it works.
I've read a lot of SF that employed that idea. The "wedge" theory makes sense to me.:wink:
  • · Replies 17 ·
9K
  • · Replies 0 ·
