Novel Multiplication and Division by odd squares
The discussion centers on a novel approach to multiplication and division involving odd integers and their squares, specifically using the notation n X A_i, where A_i represents odd integers. The key finding is that the multiplication operation is commutative, demonstrated through the equation n X A_i X A_j X A_k = n X A_k X A_j X A_i. A specific transformation is introduced, defined as n ∘ x = n x + k(x - 1), with k set to -1/8 for this context. The proof of this transformation is straightforward and confirms the commutative property of the defined operation.
  • Understanding of odd integers and their properties
  • Familiarity with triangular numbers and their calculation
  • Basic knowledge of multiplication and its commutative property
  • Concept of transformations in mathematical operations
  • Explore the properties of triangular numbers and their applications
  • Study the implications of commutativity in various mathematical operations
  • Investigate the use of transformations in algebraic expressions
  • Learn about advanced multiplication techniques in number theory
Mathematicians, educators, and students interested in number theory, particularly those exploring properties of odd integers and their operations.
ramsey2879
let [tex]A_i[/tex] be an odd integer, [tex]s_i[/tex] be the square of [tex]a_i[/tex] and [tex]t_i[/tex] be the triangular number, [tex](s_i -1)/8[/tex]. Same for [tex]a_j , s_j, t_j, etc[/tex]. Define Multiplication of [tex]n X A_i , etc[/tex] to be n * s_i - t_j and division to be the reverse of this process. I found that
n X A_i X A_j X A_k = n X A_k X A_j X A_i = n X A_j X A_k X A_i etc.
for instance ((((4 * 9 - 1)*49 - 6)*25 -3) + 1) / 9 = (4*25-3)*49-6 = (4*49-6) * 25 - 3 = B
8*4-1 = 31 and 8*B - 1 = 31*25*49
Is there a simple way to prove this general result?
I can barely make this out, since you didn't format it.
If I'm reading it right, this just follows from the commutativity of multiplication.
Yes, removing all unnecessary notation, the result your are looking for is the following:
Let k be a real number. For real numbers n and x, define n[itex]\circ[/itex]x=nx+k(x-1). Then (n[itex]\circ[/itex]x)[itex]\circ[/itex]y=n[itex]\circ[/itex](xy).
The proof of this is trivial, and your result is the special case of k=-1/8, and where nXa=n[itex]\circ[/itex]a2.
13K
