Could Quantum Geons Achieve Stability Like Bohr Atoms?
  • Context: Graduate
  • Thread starter Thread starter johne1618
    Quantum
This discussion explores the concept of quantum geons and their potential stability, drawing parallels with Bohr atoms. It highlights the photon sphere's radius formula, r = 3GM/c², and the quantization of orbital angular momentum, p·r = nħ. The analysis concludes that while classical geons are unstable, the possibility of a stable quantum geon remains uncertain due to the challenges of integrating quantum mechanics with gravity. The conversation also touches on the implications of using pure electrodynamics for quantization.
  • Understanding of photon spheres and their properties
  • Familiarity with quantum mechanics and the Bohr model
  • Knowledge of general relativity and gravitational effects on light
  • Basic concepts of electrodynamics and Laplace's equation
  • Research the implications of photon spheres in general relativity
  • Study the principles of quantum gravity and its challenges
  • Explore the quantization methods in electrodynamics
  • Investigate the stability of classical versus quantum geons
Physicists, researchers in quantum mechanics and general relativity, and anyone interested in the intersection of gravity and quantum theory.
johne1618
Apparently a photon sphere is a region of space where gravity is strong enough to cause light to travel in orbits. The radius of the photon sphere is given by
[tex]r = \frac{3 G M}{c^2}[/tex]
If one had a photon that was energetic enough then its own gravity would trap it in its own photon sphere. I believe this is John Wheeler's geon idea.
Imagine that a photon is forced into a closed orbit. By analogy with the Bohr atom its orbital angular momentum should be quantized such that:
[tex]p \ r = n \hbar[/tex]
Using the relation between energy and momentum for photons, [itex]E = p \ c[/itex], we find
[tex]E = \frac{n \hbar c}{r}[/tex]
Using the Einstein relation, [itex]E = M c^2[/itex], we can substitute the quantized photon mass/energy into the photon sphere equation. By eliminating [itex]r[/itex] we find that the mass of the resulting object is given by:
[tex]M = \sqrt{\frac{n}{3}} \sqrt{\frac{\hbar c}{G}}[/tex]
[tex]M = \sqrt{\frac{n}{3}} M_{planck}[/tex]
I know that John Wheeler concluded that classical geons are not stable. Classical photon orbits are not stable.
But could a quantum geon produced by a coherent photon orbit as described above be stable in the same way that a Bohr atom is stable?
1) Bohr atom is non-physical. I'm not sure in what sense it could possibly be (un)stable.
2) Quantum and gravity don't mix. Quantum mechanics requires a linear Hamiltonian. What you are proposing is definitively non-linear. Even if there is something in that idea, it would require Quantum Gravity of some sort to resolve.
Edit: Though, it is a photon. You might be able to get away with scrapping QM, and just trying to see if you get quantization you need from pure electrodynamics. It's not going to be pretty, though.
when you say get quantization from pure electrodynamics.
Is that like when you solve laplaces equation for like the potential in a box
and you get values based on cos(npi)
Is that what you mean?
  • · Replies 42 ·
  • · Replies 23 ·
  • · Replies 21 ·
  • · Replies 23 ·
