Proving the Summation of an Infinite Series
The discussion revolves around proving a summation involving an infinite series, specifically the expression ∑ i=1 to n √(1 + (1/i²) + (1/(1+i)²)) = n(n+2)/(n+1). Participants are exploring the validity of the statement and the steps involved in a proof by induction.
  • Mixed
  • Participants discuss the base case of the proof and the assumption of the inductive step. There are attempts to manipulate the expression to show the relationship between terms, with some participants questioning the clarity of the original statement and its notation.
Some participants have provided guidance on how to approach the induction step, suggesting algebraic manipulation and clarification of terms. There is ongoing exploration of how to connect the inductive hypothesis to the next step, with various interpretations being considered.
There are indications of confusion regarding the notation and structure of the original summation statement, with participants noting potential issues such as missing parentheses and unclear radical expressions.
andyk23
1. Homework Statement
∑ i=1 to n1+(1/i2)+(1/(1+i)2)−−−−−−−−−−−−−−−−−−−−√ = n(n+2)/n+1
2. The attempt at a solution
First I did the base case of p(1) showing 3/2 on the LHS equals the 3/2 on the RHS.
Then I assumed p(k) and wrote out the formula with k in it.
Then prove p(k+1)= p(k)+ 1+1/(k+1)2+1/(k+2)2−−−−−−−−−−−−−−−−−−−−−−√
=k(k+2)/k+1 + 1+1/(k+1)2+1/(k+2)2−−−−−−−−−−−−−−−−−−−−−−√
Then I squared each to get rid of the square root.
(k(k+2)/(k+1))^2+ (k+1)^2/(k+1)^2 + 1/(k+1)^2 + 1/(k+2)^2
Now I'm stuck any Guidance would be great thanks!
The above line is nonsensical. Not enough parentheses, probably missing exponentiation, dangling radical ...
Do you mean [itex]\displaystyle \sum_{i=1}^{n}\sqrt{1+1/(i^2)+1/(1+i)^2}\ \ = \ \ n(n+2)/(n+1)\ ?[/itex]
If so, then I must be a much better mind reader than I have ever been given credit for !
yes sorry about that!
You answered "yes" to what? Please be precise .
Yes I meant that!
As you stated: For the induction step, you assume that
[itex]\displaystyle \sum_{i=1}^{k}\sqrt{1+\frac{1}{i^2}+\frac{1}{(1+i)^2}}\ = \ \frac{k(k+2)}{k+1}[/itex]​
for k ≥ 1 . From that assumption, show that it follows that
[itex]\displaystyle \sum_{i=1}^{k+1}\sqrt{1+\frac{1}{i^2}+\frac{1}{(1+i)^2}}\ = \ \frac{(k+1)(k+3)}{k+2}\ .[/itex]​
So look at [itex]\displaystyle \ \ \sum_{i=1}^{k+1}\sqrt{1+\frac{1}{i^2}+\frac{1}{(1+i)^2}}\,,\ \[/itex] which you can write as [itex]\displaystyle \ \ \sqrt{1+\frac{1}{(k+1)^2}+\frac{1}{(k+2)^2}}+\sum_{i=1}^{k}\sqrt{1+\frac{1}{i^2}+\frac{1}{(1+i)^2}}\ .[/itex]
Now use you assumption, then do some algebra.
I'm just having a trouble showing, [itex]\frac{k(k+2)}{k+1} + \sqrt{1+\frac{1}{(k+1)^2}+\frac{1}{(k+2)^2}}\ .[/itex] = [itex]\frac{k+1(k+1)}{k+1+2}\ .[/itex]
I'm just having a trouble showing, [itex]\frac{k(k+2)}{k+1} + \sqrt{1+\frac{1}{(k+1)^2}+\frac{1}{(k+2)^2}}+\sum_{i=1}^{k}\sqrt{1+\frac{1}{i^2}+\frac{1}{(1+i)^2}}\ .[/itex] = [itex]\frac{k+1(k+1+2)}{k+1}\ .[itex][/itex][/itex]
I'm just having a trouble showing, [itex]\frac{k(k+2)}{k+1} + \sqrt{1+\frac{1}{(k+1)^2}+\frac{1}{(k+2)^2}}\[/itex] = [itex]\frac{k+1(k+1+2)}{k+1}\[/itex]
What you really need to show next is
\frac{k(k+2)}{k+1}+\sqrt{1+\frac1{(k+1)^2}+\frac1{(k+2)^2}} = \frac{\color{red}{(k+1)} (k+3)}{k+\color{red}2}.
I'd try subtracting ##\frac{k(k+2)}{k+1}## on both sides and then squaring the results.
  • · Replies 22 ·
  • · Replies 18 ·
