Solving Riccatti Equation: 2nd Order Diff. Eq.
  • Thread starter Thread starter yoyo
The discussion revolves around solving a Riccati equation, specifically a second-order differential equation represented as dy/dx = -y^2 + a(x)y + b(x). Participants explore various substitutions and transformations to convert the non-linear equation into a linear form, as well as discuss specific cases with given values for a and b.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the substitution y = u'/u to derive a linear second-order differential equation. There are questions about the correctness of the transformations and whether further steps are needed. Some participants express confusion regarding specific parts of the problem, particularly in solving for u(x) and understanding the implications of linear versus non-linear equations.
There is active engagement with multiple participants contributing their thoughts on the transformations and the implications of the Riccati equation. Some guidance has been provided regarding the substitution process and the resulting linear equation, but there is still uncertainty about the next steps, particularly in finding specific solutions and discussing the properties of linear equations.
Participants mention difficulties with the material and express concerns about the quality of instruction they are receiving. There is a focus on understanding the mathematical reasoning behind the transformations and the implications of the results, with some participants indicating they are self-studying the topic.
yoyo
Consider the following Riccatti equation:
dy/dx= -y^2+ a(x)y + b(x) (Eq. 2)
Here a(x) and b(x) are arbitrary functions.
1. Set y(x)= u'(x)/ u(x) where u(x) is a function to be determined. Use (Eq. 2) to show that u(x) satisfies a linear differential equation of second order.
2. Set a=0 and b=1. Solve (Eq. 2) by separating variables using y(0)=0 as the initial condition.
3. Find the function u(x) corresponding to the case a=0, b=1 and y(0)=0. When solving the second order equation for u(x) assume that u'(0)= y(0) and u(0)= 1. Compare the solution of (Eq. 2) from Part 2 with u'(x)/u(x).
4. Eplain why it is nice to replace a non-linear first order differential equation with a linear second order one.
Go to Top of Page
for part 1 here is what i have substituting y=u'/u
(dy/dx)= -(u'/u)^2+a(x)(u'/u)+b(x)
multiply everything by u to get:
u(dy/dx)=-u(u')^2+a(x)(u')+b(x)u
So am i done here or is there more? (I have a really lousy professor who
just barely got his phD and can't really teach. therefore i am having a lot of diffuculty understanding the matrial. i feel like i am teaching myself ODE...so please help)
No, wish to rid the equation of y and just have u's. First, just treat a(x) and b(x) as a and b with the understanding that they are functions of x ok. Then we have:
[tex]y^{'}=-y^2+ay+b[/tex]
Letting [itex]y=\frac{u^{'}}{u}[/itex] and substituting this into the ODE, we get:
[tex]\frac{uu^{''}-(u^{'})^2}{u^2}=-\frac{(u^{'})^2}{u^2}+\frac{au^'}{u}+b[/tex]
You understand this part right?
Now, multiplying throghout by [itex]u^2[/itex] and noting that there is a [itex]-(u^{'})^2[/itex] on both sides which cancel, we have:
[tex]u(u{''})=au(u{'})+bu^2[/tex]
Divide out the u and place in standard form:
[tex]u^{''}-au^{'}-bu=0[/tex]
That's a good start and it's important to understand this before going further. I assume you'll look at mine, then attempt to go through the steps on your own on paper. Next, do a similar substitution with the following more general form of the Riccati equation:
[tex]y^{'}+Qy+Ry^2=P[/tex]
Using the substitution:
[tex]y=\frac{u^{'}}{Ru}[/tex]
With Q,R, and P functions of X so when you're differentiating y remember to differentiate R as well.
Oh and we're not done here: either you or me should/could write a final report on this with at least one plot. Would be better for you if you're taking this in school but if I don't see any follow-up postings by Sun. night, I'll do so (I'm patient).
thanks for the help salty, it really pointed me in the right direction. After some calculus I was able to get u''-au'-bu=0 . however, I still can't figure out number 3, which I've written again below:
I got u''-1=0, and then rewrote it as d^y/dx^2 =1 . From here though I'm stuck.
Also, what is your opinion on number 4? is it because of the properties of a linear equation?
Thanks
Thanks
Well, if b=1 then the second order eq. in u(x) becomes:
[tex]u^{''}-u=0[/tex]
Solving this the usual way, you know how to right, gets:
[tex]u(x)=c_1e^x+c_2e^{-x}[/tex]
Now, you can plug in u'(0)=u(0)=1 into this and its derivative, get two equations, two unknowns, find [itex]c_1[/itex] and [itex]c_2[/itex].
Also, #4: non-linear equations are much harder to solve than linear equations.
  • · Replies 19 ·
