 Quote by Barry_G
I did not ask about photons propagating through region without charge, but how do you explain they are themselves electrically and magnetically neutral, considering they are (made of) electric and magnetic fields. Photon is electromagnetic field, right?
In QED, photon can be described as electron + positron. They are virtual, of course, but if you feel like there absolutely has to be a charge, maybe it will help you sleep at night.
 Quote by Barry_G
I don't see how can it be traced nor what is that supposed to explain. An electron in an atom jumps an orbit and a photon is emitted, but neither electric charge, magnetic charge, nor dipole magnetic moment of that electron changes, so what does that tells us about photon electromagnetic fields?
That's because you've only heard the explanation of transition that's given to chemists so that they don't have to think about physics too hard.
In reality, electron does not simply jump from one state to another. An atom that's emitting EM radiation as electron transitions from one energy level to another exists in superposition of two energy levels. While pure states have zero dipole moment, the superposition of any two states has a dipole expectation which rotates. So you actually do have an oscillating charge in an atom while it emits radiation.
Unfortunately, there aren't many good references on that. Pretty much the only thing I can suggest is taking the hydrogen atom solutions, composing a superposition state, say (1s+2p)/√2, and computing the dipole expectation. There is nothing really difficult about it, but it's about a page of notes.
C'mon, "purely mathematical" means there is no experimental measurements relating to that specific theory and set of equations.
Electric field in electromagnetic wave of low enough frequency can be measured directly. That's basically what radio is all about. So yes, we have very good experimental background on Maxwell's Equations, including wave solutions. Not to mention that they are used in just about every aspect of optics and electrical engineering.
Everything in physics that is part of standard theory has overwhelming experimental support. If you think something doesn't, you are simply ignorant of that branch of physics. Feel free to ask, though. Keep in mind that a lot of things are confirmed indirectly.
I thought electron and positron are carriers of the smallest amount of charge, both electric and magnetic
Neither. First of all, there is no such thing as magnetic charge. There are only dipoles, and these can be arbitrarily small. Smallest electric charge is held by down, strange, and bottom quarks at ±1/3 that of the electron. These are followed by the up, charmed, and top quarks at ±2/3. Charged leptons come in in 3rd with ±1, with electron being one of them.
What's interesting is that charge can only change by a unit of 1e, which is why electron charge is also known as elementary charge. It's like spin. You can have a fraction, but you have to change it by a unit.
I guess they just "are", but do we see such electric or magnetic fields, devoid of any carrier particles, anywhere else, and is there any explanation how can that be?
Photons ARE the carriers of electromagnetic field. I'll let you think on that for a while. Of course, again, that is QED. In classic field theory, carrier particle is not required.
So, for example when electric field goes up it's positive and when it comes down it's negative? Do they change magnitude as they transfer from one sign to another?
In linearly polarized, yes. Magnitude and direction oscillate as a sine wave. In circularly polarized, only direction changes, with magnitude remaining constant.
I don't see how any of those equations can explain why photons have zero electric and magnetic charge.
Because ρ and j are taken to be zero in that set of equations. That means there are no charges or currents present. No sources for electrostatic or magnetostatic fields. If you only consider the static solution to these equations, you will get trivial solution E=B=0 as the only possibility.
Maybe you would understand EM propagation better via retarded potentials. You can think of EM wave as being caused by electric field of the distant charge that oscillates, and because "information" about position of the charge is delayed by speed of light, you get an oscillating EM field. This is really a carriage before horse explanation, because speed of light is hand-waved into it, but again, if it makes it easier for you to understand, maybe it's worth for you to take a look.
Retarded Potential.
