| New Reply |
I am starting to doubt Ohm's law. I would like someone to point out why I am wrong. |
Share Thread |
| Dec11-12, 09:00 PM | #1 |
As the title states I am really doubting Ohm's law. This is why: On a breadboard I placed a white LED and a 220Ω resistor with the 9v battery all in series. The total current flowing through the circuit shouldn't be more than 41mA by V=IR, but my multimeter points between the range of 150-120(Edit: mA). Can someone tell me why???
Thank you. |
| Dec11-12, 09:07 PM | #2 |
Mentor
We can't help without knowing what you are doing. A circiut diagram including how the meter is connected would help. Try to diagram what you have on the breadboard.
120-150 whats? What kind of meter are you using? |
| Dec11-12, 09:14 PM | #3 |
what sort of white LED is it give us a part number ?
it may be one that draws more current Hint.... If you ever want to doubt a known physical law, assume it's something you are doing wrong, not the law ;) Dave |
| Dec11-12, 09:16 PM | #4 |
| Dec11-12, 09:18 PM | #5 |
| Dec11-12, 09:19 PM | #6 |
2) Check the accuracy of the meter (use another meter - digital might be better as it would probably change the circuit less than and analgoue one) |
| Dec11-12, 09:21 PM | #7 |
The resistance of the 220 ohm resistor comes to about 218 ohm.
| Dec11-12, 09:28 PM | #8 |
Can we verify the battery's voltage?
| Dec11-12, 09:31 PM | #9 |
you still didnt tell us what sort of LED ?? Dave |
| Dec11-12, 09:39 PM | #10 |
Recognitions:
Any LED will actually reduce voltage by about 1 - 2 volts. So the current with an LED should be even less than 41mA. 150+ mA cannot be explained by any kind of LED. anj16, can you take a picture of your setup? |
| Dec11-12, 09:50 PM | #11 |
@Dave about the part# for the LED, I have no clue. I bought in bulk off Ebay.
I have attached a picture of the setup |
| Dec11-12, 09:52 PM | #12 |
| Dec11-12, 09:56 PM | #13 |
Recognitions:
Isn't the entire + line connected on the breadboard? If so, your resistor is shorted out. Try checking resistance while it is in the breadboard.
| Dec11-12, 10:02 PM | #14 |
EDIT: Also the doubt I had is gone because I re-measured the current and it comes to about 41 mA. |
| Dec11-12, 10:37 PM | #15 |
prob solved ....
the old saying ... a pic is worth 1000 words ;) Dave |
| Dec11-12, 10:38 PM | #16 |
D |
| New Reply |
| Tags |
| ohm's law |
Similar Threads for: I am starting to doubt Ohm's law. I would like someone to point out why I am wrong.
| probability doubt - where am i wrong? | Set Theory, Logic, Probability, Statistics | 2 | ||
| Starting point of measurement | General Astronomy | 1 | ||
| starting point | Academic Guidance | 7 | ||
| starting point | Academic Guidance | 5 | ||
