What is the Default Equilibrium Constant for Chemical Reactions?
  • Thread starter Thread starter Nikitin
The default equilibrium constant for chemical reactions is not universally defined; it depends on the specific reaction and its coefficients. For the reaction 2H2 + O2 -> 2H2O, the equilibrium constant is expressed as K1 = [H2O]² / ([H2]² * [O2]). Alternatively, the reaction can be represented as H2 + 0.5O2 -> H2O, yielding K2 = [H2O] / ([H2] * [O2]⁰.⁵) = K1⁰.⁵. Generally, the equilibrium constant is provided for the balanced reaction with the smallest integer coefficients, leading to the assumption that K1 is the default value unless specified otherwise.
  • Understanding of chemical equilibrium concepts
  • Familiarity with equilibrium constant expressions
  • Knowledge of stoichiometry in chemical reactions
  • Basic algebra for manipulating equations
  • Research the derivation of equilibrium constants for various chemical reactions
  • Study the impact of reaction coefficients on equilibrium constants
  • Explore the conventions used in reporting equilibrium constants in scientific literature
  • Learn about the role of temperature and pressure in equilibrium constant values
Chemistry students, researchers in chemical sciences, and professionals involved in chemical engineering or reaction kinetics will benefit from this discussion.
Nikitin
Let's say we have the reaction 2H2 + O2 -> 2H2O. The equilibrium constant for this reaction then is: K1=[H2O]2]/([H2]2*[O2]).
But the reaction can also be written as H2 + 0.5O2 -> H2O, and with the equilibrium constant becoming K2 = [H2O]1]/([H2]1*[O2]0.5)=K10.5
This phenomena with the coefficients goes generally for all reactions. So, what K is the default one? Is it the one where most coefficients are 1 (K2), or is it when all coefficients are at their smallest, while remaining integers (K1)? Or something else?
Chemistry news on Phys.org
There is no general default. Usually you have to give the reaction equation along with the equilibrium constant.
Most often you will see the equilibrium constant for the properly balanced reaction equation - that is, with all coefficients being the smallest possible integer numbers. So when there is no other information I would assume value given is K1. Serious sources of equilibrium constants usually define the convention used, to make the information unambiguous.
Which basically boils down to what DrDu wrote earlier.
