Projectile motion of a salmon jump
The discussion focuses on calculating the minimum speed a salmon must achieve to jump over a 0.55 m waterfall while starting 2 m away at an angle of 32 degrees. The required speed is determined to be 6.2 m/s. Participants emphasize the importance of understanding vector addition and the parabolic motion of objects under gravity, specifically using the equations of motion to derive the initial velocity needed for the jump.
  • Understanding of projectile motion and parabolic trajectories
  • Familiarity with vector addition in physics
  • Knowledge of basic kinematic equations
  • Concept of gravitational acceleration (-9.8 m/s²)
  • Study the derivation of kinematic equations for projectile motion
  • Learn about vector decomposition in two dimensions
  • Explore examples of real-world applications of projectile motion
  • Investigate the effects of air resistance on projectile trajectories
Students studying physics, educators teaching mechanics, and anyone interested in the dynamics of animal locomotion and projectile motion principles.
Gunk
I am having problems with this section. Any help is appreciated.
Salmon often jump water falls to reach their breeding ground. Starting 2 m from a waterfall .55 m in height, at what minimum speed must a salmon jumping at an angle of 32 degrees leave the water to continue upstream?
The answer is 6.2 m/s. The problem is I really don't know where to begin. I figured that I would do some vector addition with 2(sin32) but that didn't lead me anywhere. Thanks for any help.
Don't just start putting numbers together without thinking it out.
2 sin(32) would give you a distance (actually, it's 2 cos(32) you would want for height) but that's assuming a straight line jump which just doesn't happen. If you are expected to do problems like this then you should know that objects moving under constant gravity with no air resistance move in parabolas.
This is a fairly standard "acceleration vector, velocity vector, position vector" problem.
You know, since this is a surface of the earth, no air resistance, problem, that the acceleration vector is -9.8 j (j is the vertical unit vector). The initial velocity vector is v0 cos(32)i+ v0 sin(32)j
where v0 is the (unknown) initial speed. (If you don't see how I got that, draw a picture showing the velocity vector at 32 degrees to the water and think "right triangle".)
You should be able to calculate, then, that the "position vector" is
vo cos(32)t i+ ((vo cos(32) t- (9.8/2) t2)j.
Now! When the salmon has moved 2 meters horizontally (to the waterfall), we must have vo cos(32) t= 2. That depends on both v0 and t. At that time, to make it over the waterfall, the salmon must have height at least that of the waterfall: the vertical distance moved must be vo cos(32)- (9.8/2) t2= 5.5.
You can solve those two equation for vo and t.
Oops. That last equation should be
vo cos(32) t - (9.8/2) t2= 5.5.
You don't really need to solve for t:
From v0 sin(32) t= 2, we have t= 2/(v0 sin(32)).
Put that into the other equation and solve for v0.
