Please Please help me in this Diffraction problem
  • Thread starter Thread starter shaiqbashir
    Diffraction
The discussion focuses on solving a diffraction problem involving four slits, where the electric field at point P is expressed as E(r, theta, t) = A(r) sin(N delta phi/2) cos(kr - wt) / sin(delta phi/2). The user successfully solved part (a) by determining the angles for interference minima as θ1 = arcsin(-λ/(2Nd)) and θ2 = arcsin(λ/(2Nd)). For part (b), the spacing between the minima is defined as Δθ = arcsin(λ/(2Nd)) - arcsin(-λ/(2Nd)), and the comparison with two slits yields Δθ2 = arcsin(λ/(2d)) - arcsin(-λ/(2d)). The ratio of spacings is Δθ/Δθ2 = (arcsin(λ/(2Nd)) - arcsin(-λ/(2Nd))) / (arcsin(λ/(2d)) - arcsin(-λ/(2d))).
  • Understanding of wave interference principles
  • Familiarity with trigonometric functions and their applications in physics
  • Knowledge of the diffraction formula for multiple slits
  • Basic grasp of electric field equations in wave mechanics
  • Study the derivation of the diffraction pattern for multiple slits using the formula E(r, theta, t)
  • Explore the implications of varying slit numbers on interference patterns
  • Learn about the physical significance of minima and maxima in wave interference
  • Investigate the differences in diffraction patterns between single, double, and multiple slits
Students and professionals in physics, particularly those focusing on optics and wave mechanics, as well as educators teaching diffraction concepts in advanced physics courses.
shaiqbashir
Hi!
please help me in the following problem?
"The electric field at point P due to N slits is,
E (r, theta, t) = A(r) sin N delta phi/2 cos(kr-wt)
_____________
sin delta phi/2
where delta phi=kdsin (theta) , "d" being the spacing between the adjacent slits. let N=4
(a) Find two angles on either side of theta=0 at which there is an interference minima.
(b) Find the spacing between the minima compare to the case of only two slits of separation "d".
Now i have solve its (a) part but i just can't solve its (b) part.
Can u please help me in this pleasezzzzzzzzzzzzzzzz.
Thanks in advance!
For part (a), the two angles on either side of theta = 0 at which there is an interference minima are given by: θ1 = arcsin(-λ/(2Nd)) and θ2 = arcsin(λ/(2Nd)) where λ is the wavelength. For part (b), the spacing between the minima are given by the difference between the two angles, θ2 - θ1. This can be expressed as: Δθ = arcsin(λ/(2Nd)) - arcsin(-λ/(2Nd)) The spacing between the minima for a case with only two slits of separation d is given by: Δθ2 = arcsin(λ/(2d)) - arcsin(-λ/(2d)) The ratio of the spacing between the minima in the two cases is given by: Δθ/Δθ2 = (arcsin(λ/(2Nd))- arcsin(-λ/(2Nd)))/(arcsin(λ/(2d)) - arcsin(-λ/(2d))) Hope this helps!
Hi there!
I'd be happy to help you with this problem. Let's start by reviewing the formula for the electric field at point P due to N slits.
E (r, theta, t) = A(r) sin N delta phi/2 cos(kr-wt) / sin delta phi/2
We can see that the spacing between the slits, "d", is included in the value of delta phi, which is equal to kdsin(theta). This means that as theta changes, the value of delta phi will also change.
(a) To find the angles at which there is an interference minima, we need to set the numerator of the electric field formula to 0. This is because interference minima occur when the waves from each slit are completely out of phase, resulting in destructive interference.
So, setting the numerator to 0, we get:
sin N delta phi/2 = 0
Since A(r) and cos(kr-wt) are not equal to 0, we can ignore them for now.
Using the trigonometric identity sin x = 0 when x = nπ, where n is an integer, we can rewrite the above equation as:
N delta phi/2 = nπ
Using the value of delta phi = kdsin(theta), we get:
N kdsin(theta)/2 = nπ
Solving for theta, we get:
theta = arcsin (nπ / Nkd)
Since we are interested in finding two angles on either side of theta = 0, we can take n = 1 and n = -1.
So, the two angles on either side of theta = 0 at which there is an interference minima are:
theta1 = arcsin (π / Nkd)
theta2 = arcsin (-π / Nkd)
(b) To find the spacing between the minima, we can use the formula for the spacing between two consecutive interference minima:
Δx = λ / sin(theta)
Since we are comparing the spacing between the minima for N slits to the case of two slits, we can use the value of theta = π / Nkd for N slits, and theta = π / kd for two slits.
So, the ratio of the spacing between the minima for N slits to that of two slits is:
  • · Replies 34 ·
