Speed of light, and path of travel, in distorted time-space
The speed of light and its path of travel are affected by gravitational distortions in time-space, as evidenced by the interaction between the sun and Earth. When a photon travels from the sun to Earth, its path is longer due to the curvature of space-time caused by gravity. Although the local speed of light remains constant, the average speed of the photon is reduced when traversing areas influenced by gravitating bodies. This phenomenon indicates that light takes more time to cross a defined circumference that includes mass, despite local clock rates being affected similarly by gravity.
  • Understanding of general relativity and its implications on time-space
  • Familiarity with the concept of gravitational time dilation
  • Knowledge of photon behavior in gravitational fields
  • Basic principles of quantum entanglement
  • Research the effects of gravitational lensing on light paths
  • Study the implications of general relativity on time dilation and light speed
  • Explore the behavior of quantum entangled photons in varying gravitational fields
  • Investigate experimental evidence supporting gravitational effects on light, such as the Pound-Rebka experiment
Physicists, astrophysicists, and students of general relativity interested in the effects of gravity on light propagation and time-space distortion.
San K
How is the speed of light, and path of travel, effected in time-space distorted (by say, gravity)?
We know that the sun/earth's gravity distorts time-space.
So when a photon travels from sun to earth...as it nears the earth...
how much length would the photon travel?
Would it be slightly more than the "straight line" (or "un-distorted space-time") distance?Alternatively
lets assume that if there were no gravity (i.e. assume that sun and Earth were mass-less or very light)...and that the photon would travel the distance between the sun and Earth in say exactly 8 mins
now with gravity (sun and Earth factored in with their actual masses) would the distance be slightly more due to space-time distortion? how much time would the photon now take?
Yes, light needs more time to cross an area of the same circumference, if the circumference encloses gravitating bodies. The local speed of light is still constant, because the local clocks are also slowed down by gravity. But globally the average speed of the pulse is slowed down.
ok. thanks AT
I wonder how (quantum) entangled photons would behave when one of them enters a circumference that encloses gravitating bodies (not sure which forum this should be posted in)
  • · Replies 93 ·
  • · Replies 57 ·
  • · Replies 19 ·
  • · Replies 65 ·
14K
