New Reply
Geometry Problem
Share Thread Thread Tools
Dec16-12, 01:35 PM   #1
Geometry Problem
Hi all
I work on the rail roads and I am trying to solve a geometry problem which I was hoping someone could help me with.
My problem is this:-
I have a straight rail road. At point A trains can divert onto another road, the other road is curved with a radius (R1), the curvature of the road changes to R2.
If I was to continue to travel along the straight rail road then what would be the offset from some distance travelled along the straight (AB) to the top of the 2nd curve.
In simple terms how is offset BC calculated.
I’m not much of a math’s wiz so I could really use a hand. I have made a drawing to illustrate what I am trying to calculate.
I really want to understand where and how it is calculated.
Can anyone shed any light?
Thanks guys
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Dec16-12, 02:22 PM   #2
Would Pythagoras work?
CL2 = AB2 + BC2
.. BC= √(CL2-AB2)
(this is just a quick little stab at the problem).
Dec16-12, 02:42 PM   #3
I am assuming from your description that AB is tangent to the first circle at A.
The perpendicular offsets from a tangent to circular curve are given by
Offset = (length along tangent)2 / twice radius
This will get you as far as D.
At D I'm not sure what happens.
Are you saying that at D the two circles have a common tangent?
Or do you need to insert a transition curve between the circles?
http://physicsforums.com/showthread....ghlight=offset
Dec16-12, 02:58 PM   #4
Geometry Problem
Thats correct at D both circles share a common tangent.
Quote by Studiot View Post
Dec16-12, 03:10 PM   #5
So once you know where D is, you can use the same method to get to C.
New Reply
Thread Tools
Similar Threads for: Geometry Problem
Thread Forum Replies
Geometry Problem in Context of Image-Charge Problem (Griffiths,p. 125, [3.15],[3.16]) Advanced Physics Homework 1
Simple geometry problem but only using geometry Calculus & Beyond Homework 7
Geometry problem General Math 14
a problem in geometry Introductory Physics Homework 7
