Thread Closed
Another quick please tell me if my logic seems correct (change of variables)
Share Thread Thread Tools
Mar4-05, 01:44 PM   #1
I'm trying to evaluate the double integral
[tex]\int \int \sqrt{x^2 + y^2} \, dA[/tex]
over the region R = [0,1] x [0,1]
using change of variables.
Well, after fooling around, I've got an answer. I set u = x^2, v =y^2, and then calculated the jacobian of T which was 1. The image transformation limits of integration for u and v turned out to be the same [0,1] x [0,1]
So I did the following calculation (both integrals going from 0 to 1)
[tex]\int \int \sqrt{u + v} * (1) dudv[/tex]
which resulted in a value of roughly 3.238.
Does my logic and answer seem sound here? Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar4-05, 02:52 PM   #2
Converting to rectangular coordinates would probably be easier
Mar4-05, 02:53 PM   #3
That's cylindrical coordinates, sorry
Mar4-05, 03:19 PM   #4
Answered in Calculus and Analysis.
Mar4-05, 03:41 PM   #5
I'm totally at a loss here guys. I realized my Jacobian was computed wrong. Can someone please give me a clue as to what would be the most efficient integral setup? I'm completely dumbfounded. :( Thanks
edit: more in-depth post in the calculus forum, thanks
Mar4-05, 04:19 PM   #6
Recognitions:
Homework Helper Homework Help
Please,DO NOT DOUBLE POST!!
Daniel.
Mar6-05, 05:19 PM   #7
Dexter...you need to drop the intensity down a notch. And to the ninja, just convert [tex] x^2 + y^2 [/tex] to [tex] r^2 [/tex] and integrate over the same area in cylindrical.
Mar6-05, 06:53 PM   #8
Recognitions:
He can't do that,the square [0,1]*[0,1] is not equivalent to the quarter of the circle you're implying...
Daniel.
Thread Closed
Thread Tools
Similar Threads for: Another quick please tell me if my logic seems correct (change of variables)
Thread Forum Replies
Is my logic correct? -- L. Algebra question Calculus & Beyond Homework 6
[SOLVED] Logic gates problem...Need to check if my answers are correct.. Introductory Physics Homework 2
Derivative as a rate if change - is this correct? Calculus & Beyond Homework 2
change of variables Introductory Physics Homework 9
QUICK Someone please tell me if my answer/logic is correct please(triple integral) Introductory Physics Homework 4
