New Reply
Sky color
Share Thread
Dec18-12, 06:56 AM   #1
Sky color
Hello,
I have a novice question.
I know that the sky color is blue (at noon, when there is no clouds), because the air particles (mostly N2 and a little O2 ...and other) scatter short-wavelength light more than longer wavelengths.
That is why we can't see the stars trought the atmosphere in daytime (the scattered light is with much more intensity then the light emmited from the brightest star).
The question is why the stars can see us? All the pictures taken from above the atmosphere show the landscape of earth trought the atmosphere, where in the landscape is noon.
PhysOrg.com astronomy news on PhysOrg.com
>> Three centaurs follow Uranus through the solar system
>> Final curtain for Europe's deep-space telescope
>> Hubble spots a very bright contortionist
Dec18-12, 08:03 AM   #2
Mentor
When viewed from say, the moon, the eart is much, much brighter than any star.
Dec18-12, 08:12 AM   #3
Quote by russ_watters View Post
So the reflected light from earth is brighter then the scattered light from atmosphere?
Dec18-12, 11:01 AM   #4
Sky color
Quote by xzardaz View Post
Yes. Although when it comes to stars it is possible to view the brighter stars during the day even with just a amateur telescope due to how extended sources (the sky) and point sources (stars) behave with increased magnification.
Note: If you don't know what you are doing never use a telescope while the sun is up...
Dec19-12, 07:28 AM   #5
Compare Moon in daytime sky. It is clearly visible against blue sky - although not as bright as many objects on ground or in sky lit by the same sunlight.
In clear sky, the disc of Sun is easily visible against blue sky, too. Since stars are inherently as hot as Sun, or slightly hotter or cooler, you should be able to magnify stars even in daytime sky to be almost as bright and distinctive, or even brighter and more distinctive, than Sun. Provided you are applying magnification starting hundreds of thousands of times, and apertures matching this (i. e. over a kilometre).
New Reply
Similar discussions for: Sky color
Thread Forum Replies
Calculating Color temperature and Color Rendering Index.. General Physics 9
Why an object has the color complementary to the color absorbed? General Physics 2
Questions about the gluons, their color and anti-color charges and charge of quarks High Energy, Nuclear, Particle Physics 15
Mathematica PlotStyle->{color,color,color} not working Math & Science Software 3
Extraterrestrial sky color based on atmospheric composition and sun color General Astronomy 4
