Is Mass a Form of Energy According to E = mc²?
  • Context: Undergrad
  • Thread starter Thread starter cdux
    Energy Mass Velocity
The discussion centers around the interpretation of the equation E = mc² and its implications regarding the relationship between mass and energy. Participants explore the nuances of this relationship, including the role of the speed of light (c) and the implications of special relativity.
  • One participant questions why popular science claims energy is a form of mass, suggesting that the presence of 'c' in the equation complicates this interpretation and raises the possibility that velocity might be considered energy.
  • Another participant argues that the formula E = mc² is incomplete, proposing a more complex expression that incorporates relativistic effects, indicating that energy is the temporal component of the energy-momentum vector.
  • It is noted by a participant that c² serves as a conversion factor rather than representing velocity, and that mass can be expressed in energy units, particularly in particle physics.
  • Further, a participant mentions the ability to convert between various units of energy, mass, and momentum, as well as between energy and temperature, highlighting the interconnectedness of these concepts.
  • One participant emphasizes that the correct interpretation is that mass is a type of energy, clarifying that E = mc² quantifies the energy associated with mass, and distinguishes this from energy due to motion.
Participants express differing views on the interpretation of E = mc², with no consensus reached on whether mass is a form of energy or vice versa. The discussion remains unresolved regarding the implications of the equation and its interpretation in popular science.
Participants highlight the need for clarity in the definitions and interpretations of mass and energy, as well as the potential for confusion stemming from popular science explanations. The discussion reflects varying levels of understanding of special relativity and its mathematical framework.
cdux
Why does popular science say that Energy is a form of Mass because of E = mc^2, when there's also 'c' in that equation? Isn't velocity energy in that train of thought? Or is it not at least part of the story?
The formula isn't even correct. It must read
[tex]E=\frac{m c^2}{\sqrt{1-\vec{v}^2/c^2}}.[/tex]
The energy is the temporal component of the energy-momentum vector
[tex]p=\begin{pmatrix}<br /> E/c \\ \vec{p} \end{pmatrix}=<br /> \frac{m}{\sqrt{1-\vec{v}^2/c^2}}\begin{pmatrix}<br /> c \\ \vec{v} <br /> \end{pmatrix}.[/tex]
The reason is that nowadays we clearly understand the mathematical structure of special relativity thanks to Minkowski's work from 1908. According to this modern point of view mass is a scalar and energy the temporal component of the above given four-vector. Why popular-science-book writers don't take up this much clearer convention but stick to the pre-Minkowskian mystification is an enigma to me!
c^2 in that equation is just a conversion factor, it is not the velocity of anything. You could give every mass in units of energy, and the equation (for particles at rest) would be E=m. In particle physics, this is quite common - particle masses are usually given in units of energy.
That's right, and you can do similar conversions between the units of energy, mass and momentum and between the length and time. Going a bit outside relativity, you can convert between the units of energy and temperature. And in quantum mechanics you can convert between length/time and energy/mass/momentum, but it is an inverse proportionality.
If they say that, then they have it exactly backwards. The correct statement is that mass is a type of energy; and that [itex]E = mc^2[/itex] states how much energy is associated with mass m. The statement needs to be made in this way specifically to be clear that energy due to motion is not in any way equivalent to mass.
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 55 ·
  • · Replies 131 ·
13K
  • · Replies 17 ·
  • · Replies 62 ·
