Help with relativistic momentum question
The discussion focuses on calculating the speed of a Pion resulting from the decay of a D meson at rest into a Kaon and a Pion, using conservation of momentum principles. The Kaon has a mass of 0.494 GeV/C² and moves at 0.867c, while the Pion has a mass of 0.140 GeV/C². The initial momentum of the D meson is zero, leading to the equation γ₁m₁v₁ = γ₂m₂v₂. The user encountered an error resulting in a speed greater than light, which was identified as a mistake in rearranging the equations. The recommendation is to utilize energy and momentum instead of velocities for simplification.
  • Understanding of relativistic momentum (P = γmV)
  • Familiarity with Lorentz factor (γ = 1/√(1 - v²/c²))
  • Knowledge of energy-momentum relations in special relativity
  • Basic concepts of particle physics, including mass-energy equivalence
  • Learn about energy-momentum conservation in special relativity
  • Study the relationship between speed, momentum, and energy (v/c = p/E)
  • Explore advanced applications of Lorentz transformations
  • Investigate the implications of relativistic speeds on particle decay processes
Students and educators in physics, particularly those studying particle physics and special relativity, as well as anyone involved in solving relativistic momentum problems.
DunWorry
a D meson is at rest and decays into a Kaon and a Pion. The Kaon moves with speed 0.867c and has a mass of 0.494 GeV/C^2. The pion has a mass of 0.140 GeV/C^2. use conservation of momentum to calculate the speed of the Pion.
Relativistic Momentum P = [itex]\gamma[/itex]mV
where [itex]\gamma[/itex] is [itex]\frac{1}{\sqrt{1 -\frac{v^{2}}{c^{2}}}}[/itex]
So if the D meson is initally at rest, initial momentum = 0, which means
[itex]\gamma[/itex][itex]_{v1}[/itex]m[itex]_{1}[/itex]v[itex]_{1}[/itex] = [itex]\gamma[/itex][itex]_{v2}[/itex]m[itex]_{2}[/itex]v[itex]_{2}[/itex]
Where particle 1 is the Kaon and particle 2 is the Pion, we want the speed of Pion so we solve for v[itex]_{2}[/itex]
After some rearrangement I got v[itex]_{2}[/itex][itex]^{2}[/itex] = [itex]\frac{1} {\frac{m_{2}^{2}}{(\gamma_{v1}m_{1}v_{1})^{2}} + \frac{1}{c^{2}}}[/itex]
After plugging in the numbers m2[itex]^{2}[/itex] = ([itex]\frac{0.140x10^{9}}{(3x10^{8})^{2}}[/itex])[itex]^{2}[/itex]
and m1[itex]^{2}[/itex] = ([itex]\frac{0.494x10^{9}}{(3x10^{8})^{2}}[/itex])[itex]^{2}[/itex]
and [itex]\gamma[/itex][itex]_{v1}[/itex] = [itex]\frac{1}{\sqrt{1 - 0.867^{2}}}[/itex]
I get an answer faster than light, where have I gone wrong?
I would expect that your rearrangement is wrong. Even if you use wrong numbers for the masses, the speed has to be below the speed of light in every relativistic calculation.
Edit: After a closer look at your equation, v2 calculated there should always be below c. The formula might be right, but then your evaluation is wrong.
In special relativity problems, you'll find it generally better to stick to working with energy and momentum rather than velocities as it simplifies the algebra quite a bit. Try finding E and p for the pion. Once you have those, you can find its speed using the relation v/c = pc/E.
  • · Replies 16 ·
