Related Rate - Rate of The Change in Distance of Two Ships
The discussion revolves around a related rates problem involving two ships, where Ship A is moving west and Ship B is moving north. The objective is to determine the rate of change of the distance between the two ships after a specified time. Participants are exploring the relationships between the distances traveled by each ship and the overall distance separating them.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants are attempting to apply the Pythagorean theorem to relate the distances of the ships. There are questions about the correct formulation of the distance function and how to derive it with respect to time. Some participants express confusion regarding the application of derivatives and the chain rule in this context.
There is ongoing exploration of how to express the distance between the ships as a function of time. Some participants have provided hints and suggestions for using coordinates and the chain rule, while others are still grappling with the concepts and seeking clarification on the relationships involved.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is also a noted confusion regarding implicit differentiation and its relevance to the problem at hand.
Astrum
Ship A is 100 km west of ship B. Ship A is moving at 35 km/h (west), ship B is moving at 25 km/h (north). Find the rate of change of the distance between the two ships after 4 hours.
the distance between the two ships is shown by
[itex]a^{2}+b^{2}=c^{2}[/itex]
Am I right to assume:
[itex][\frac{ds_{a}}{dt}]^{2}+[\frac{ds_{b}}{dt}]^{2}=[\frac{ds_{c}}{dt}]^{2}[/itex]
So, I need to find the rate of change of C? After 4 hours, the ships are 260 km apart.
I need a helping hint.
Can you write the distance apart as a function of the time t? Your derivative formula isn't correct.
You mean like d=vt? I'm highly confused. I'm not sure how to relate the total distance C with d=vt.
Pick coordinates. Suppose A is at (0,0) at time t=0 and B is at (100,0). Where are they at another time? You figured out the distance at t=4. Just do it for any t.
at time t, they're at [itex]d_{a}=35t[/itex]
[itex]d_{b}=25t[/itex].
You can't describe locations in the plane with a single number. Use coordinates.
Ok, I'm not following. Let me try another example.
A pile of gravel is being poured from a belt at a rate of 20 m cubed per min. The base will always be half the height. How fast the the pile changing when h=10m?
So, you take the equation for the volume of a cone. take the derivative with respect to h. And we also have the change in volume with respect to time. How do we relate all this to time?
We have [itex]\frac{dV}{dh}=\frac{1}{4}\pi h^{2}[/itex]
And: [itex]\frac{dV}{dt}=20m^{3}/s[/itex]
Now what? We have these two derivatives. This is the part I don't understand.
Ok. How about using [itex]\frac{dV}{dh} \frac{dh}{dt}=\frac{dV}{dt}[/itex]? That's the chain rule. You can use the same approach for the first one if you clearly define what a, b and c are.
Assume at the start that ship B is at a reference point.
At any time t, let a be distance of ship A from the reference point, and let b equal the distance of ship B from the reference point.
[itex]\[<br /> a = 35t + 100,\quad b = 25t<br /> \][/itex]
Now, let h be the distance between the two ships at any time t, so that, by pythagorean theorem,
[tex]\[<br /> \begin{array}{l}<br /> h^2 = a^2 + b^2 \\ <br /> h^2 = \left( {35t + 100} \right)^2 + \left( {25t} \right)^2 \\ <br /> \end{array}<br /> \][/tex]
and using suitable steps,
[tex] \[<br /> h = 5\sqrt {74t^2 + 280t + 400} <br /> \][/tex]
You should be able to understand, and then continue and finish the exercise from this.
[itex]\frac{dV}{dh} \frac{dh}{dt}=\frac{dV}{dt}[/itex] = [itex]\frac{1}{4}\pi h^{2}\frac{dh}{dt}[/itex] = 20
At this point we plug in 10 for h? so that means [itex]\frac{dh}{dt}[/itex]=.255?
Sure.
Dick said:
Sure.
So that begs the question, WHY is this correct? I can't find anything to explain it clearly. I don't know why you just plug in dh/dt
Astrum, what are you asking in post #7? How fast is height, h changing when it is 10 meters?
Let me try.
b is base, r is radius, given base is half of height h. Radius is half of b.
[tex] \[<br /> \begin{array}{l}<br /> {\rm }b = {\textstyle{1 \over 2}}h \\ <br /> {\rm }r = {\textstyle{1 \over 2}}b \\ <br /> \end{array}<br /> \]<br /> [/tex]
[tex] \[<br /> V = \frac{\pi }{{3 \cdot 8}}h^3 <br /> \][/tex]
V and h are functions of time. V is a function of h, but both of them are functions of time. That is why you use Chain Rule when you find derivative of the right-hand side.
note: may need to check my V result carefully in case arithmetic mistakes; but I believe they're good.
EDIT: Now the formatting in the post is not working. I'll try in the next post.
base b is half of height h,
radius is half of b,
[tex]\[<br /> \begin{array}{l}<br /> b = \frac{1}{2}h \\ <br /> r = \frac{1}{2}b \\ <br /> \end{array}<br /> \][/tex]
[tex]\[<br /> V = \frac{\pi }{{3 \cdot 8}}h^3 <br /> \][/tex]
Yes. I'm just confused as to how you can get dh/dt in there. My confusion comes form not understand implicit differentiation 100%.
Implicit differentiation is unnecessary. You can start (or continue) with the formula for volume of the cone, and this is a function of height, h. You need a bit of substitution as I showed to put the expression in the form as I have.
THEN,
  1. Differentiate V with regard to t,
  2. Use Chain Rule to differentiate h with regard to t, because h is a function of t.
Like I was saying in post 8, implicit differentiation is really just using the chain rule. Do you understand the chain rule?
THEN,
I am possibly unclear about what is and is not implicit differentiation. I have not reviewed it specifically, so I have learned (or relearned) how to find derivative without deciding if I am doing so "implicitly" or not.
Simply, V and h both are function of t; so one differentiates both sides of the formula with respect to t.
  • · Replies 21 ·
9K
  • · Replies 25 ·
