New Reply
throttling in thermodynamics
Share Thread Thread Tools
Dec25-12, 08:54 PM   #1
I am a new starter on thermodynamics, here is my question.How does a throttle work?
I can understand the equation behind throttling process, how enthalpy is conserved...etc
But I cannot understand how throttle actually achieve the decrease in pressure? is it through turbulent the flow?
Thanks in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Dec27-12, 10:37 AM   #2
Your question is similar to one way back when.
http://www.physicsforums.com/archive...p/t-67757.html
Dec27-12, 06:24 PM   #3
It isn't the throttle that causes the pressure decrease. The fluid flows from a region of high pressure to a region of low pressure and there expands at constant enthalpy, according to Bernoulli's equation.
Yes, a throttle has a high pressure side and a low pressure side and fluid passes from one to the other through the throttle, but the pressure is set by conditions on each side.
So for instance the high pressure side might be a container of fluid at high pressure that is expanded into a large chamber at lower pressure or even the atmosphere, which maintains the low pressure.
The high pressure may be maintained by the size of the reservoir, or by flow into the reservoir.
New Reply
Thread Tools
Similar Threads for: throttling in thermodynamics
Thread Forum Replies
The principle behind throttling valves Mechanical Engineering 36
Throttling a Gas Cylinder Materials & Chemical Engineering 7
air throttling (real gas) Introductory Physics Homework 0
when flowing fluid passes through throttling there is a drop in Mechanical Engineering 5
Throttling Process Engineering Systems & Design 7
