Calculate the force on a circular surface
The problem involves determining the normal and tangential components of a force applied to a circular surface by a probe. The context includes the application of Newton's laws and trigonometric relationships to analyze the force's projections based on the horizontal position of the probe.
  • The original poster attempts to express the force components in terms of trigonometric functions and questions the discrepancy between their results and those found in a textbook. Participants discuss the definitions of variables and suggest substituting trigonometric identities to align with the textbook answers.
Participants are actively engaging in clarifying the definitions of variables and the relationships between trigonometric functions. Some guidance has been provided regarding the use of sine and cosine, and there is an ongoing exploration of how to derive the equations for the force components.
There is mention of an attachment with a diagram that is not visible in the discussion, which may contain crucial information for understanding the problem setup. The original poster expresses uncertainty about specific terms used in the textbook answers.
jonjacson
Hi to everybody
(The attachment has an image with this problem)
A small probe P is gently forced against the circular surface with a vertical force F as shown. Determine the n- and t-components of this force as functions of the horizontal position s.
Newton laws and basic trigonometric relationships.
Well I show in the attachment my reasoning, the force F is applied at the contact point C, I have represented the direction in which this force acts (vertical line). I need to find the proyections of F to the n and t axis, to calculate Fn and Ft in red.
Well I think that the angle between the vertical line and the line connecting the center O and the point C is the same angle between F and Fn, in the picture they are called A. I simply write:
Fn= F cos(A)
Ft= F sen(A)
And I can calculate A as:
A=arcsen(s/r)
But I have seen the answers provided in the book and they are:
Ft=Fs/r
and
Fn= -(F√(r2-s2))/r
Does anybody know what is Fs?
And I have no idea where the equation for Fn comes from.
Why are my answers so different to the ones in the book?
Thank you
"Fs" is F*s, not Fs. Looks like they are avoiding using sin, cos in the answer.
jonjacson said:
Fn= F cos(A)
Ft= F sen(A)
A=arcsen(s/r)
Looks good. (The sine function is generally written sin rather than sen.) From A=arcsin(s/r) you get sin(A) = s/r. Try substituting this expression for sin(A) into your expression Ft= F sin(A) and compare to answer in book.
How would you write cos(A) in terms of s and r?
Yes you are right, thank you very much.
The sinus is simply s/r and I get the Ft.
For the Fn it´s the same, they avoid to use the cos, to calculate the other leg of the triangle I use the pythagorean theorem r2=s2+y2 where I called y the other leg of the triangle. So the cosinus is exactly the answer in the book.
Thank you very much to both of you, I have more doubts with problems in this book, hope to see you in the other threads.:biggrin:
  • · Replies 20 ·
