New Reply
Energy Stored in a spring
Share Thread Thread Tools
Jan2-13, 05:05 AM   #1
Why is the energy stored in a spring 1/2 * distance * force? Isn't work just force * distance?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan2-13, 05:42 AM   #2
Quote by GeneralOJB View Post
The full force is not applied for the full distance.
In the simple case of a constant force over a fixed distance you can just multiply force by distance. But in the case of a spring being compressed, the force is not constant.
You could approximate the answer by analyzing the situation in small steps... You compress the spring the first 1/10th of the distance using 1/10th of the full force, the next 1/10th of the instance using 2/10th of the total force and so on. This approach would give you an answer that is pretty close.
An exact answer can be obtained by using calculus and integrating instantaneous force over incremental distance. That answer turns out to be 1/2 * distance * maximum-force
Jan2-13, 05:53 AM   #3
Thanks, I understand now.
New Reply
Thread Tools
Similar Threads for: Energy Stored in a spring
Thread Forum Replies
stored spring energy Introductory Physics Homework 4
Energy stored while loading a spring Introductory Physics Homework 4
stored energy in a spring Classical Physics 6
Energy stored in a spring Introductory Physics Homework 11
potential energy stored in a spring.... Introductory Physics Homework 1
