New Reply
calculate the change of volume from volume expansion coefficient
Share Thread Thread Tools
Jan2-13, 08:05 AM   #1
β= (1/v)(∂v/∂T)constant pressure.
What is the v represent? molar volume?
If I am given the β and the change of temperature, how to calculate the change of volume? or it is not enough information to calculate it?
Thank you.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Jan2-13, 08:52 AM   #2
it seems like you have enough if the change is relatively small so that you could use deltas:
beta * delta T * V =delta V
You'd have to decide on what relatively small means and you have to know what V is.
Jan2-13, 09:15 AM   #3
Thank you
Question : a container is filled with mercury at 0 degree Celcius. At temperature 50 degree Celcius , what is the volume of mercury that will spill out ?
β Of mercury is 18*10^(-5) /Celcius
Is this possible to do ?
Jan2-13, 10:20 AM   #4
Quote by Outrageous View Post
Thank you
What do you think? A delta of 50 degrees is pretty significant.
What is the initial volume?
Jan2-13, 05:50 PM   #5
The initial volume is not given , so that question can't be solved?
Jan2-13, 08:14 PM   #6
Recognitions:
Gold Membership Gold Member
Thank you.
Rewriting your equation:
[tex]\frac{d\ln{v}}{dt}=\beta[/tex]
Integrating, you get:
[tex]v=v_0\exp(\beta(T - T_0))[/tex]
where v0 is the volume at temperature T0.
New Reply
Thread Tools
Similar Threads for: calculate the change of volume from volume expansion coefficient
Thread Forum Replies
Please Help! Coefficient of Volume Expansion Question Introductory Physics Homework 0
Temperature Change and Volume Expansion Introductory Physics Homework 3
Proving coefficient of volume expansion Introductory Physics Homework 2
volume expansion problem...wheres initial volume? Introductory Physics Homework 2
volume expansion and pressure change Introductory Physics Homework 8
