Calculating Water Flow into a Pipe
The discussion centers on calculating the rate of water flow into a gas pipe with a 40mm hole, subjected to a constant water pressure of 4000 millibar. The original poster seeks to apply Bernoulli's principle and the equation Q = A x v to determine the flow rate. However, a participant advises that the immediate priority should be repairing the gas pipe rather than calculating the flow rate, emphasizing the urgency of addressing the gas leak over theoretical calculations.
  • Understanding of Bernoulli's principle
  • Familiarity with fluid dynamics equations
  • Knowledge of pressure measurement units (millibar)
  • Basic concepts of gas and water pipe systems
  • Research Bernoulli's equation applications in real-world scenarios
  • Explore fluid dynamics simulations for leak detection
  • Learn about gas pipe repair techniques and safety protocols
  • Investigate pressure measurement tools and their calibration
Engineers, plumbers, safety inspectors, and anyone involved in fluid dynamics or gas pipeline maintenance will benefit from this discussion.
Bob_
Hi all,
I have a practical problem at work that I need some help with please!
In the ground, there is a gas pipe that runs alongside a burst water pipe. There is a hole in the gas pipe of approx 40mm in diameter, and the water is blasting the hole with constant water pressure of 4000 millibar.
Any idea how to work out rate of water flow entering the hole in the gas pipe?
Any help much appreciated! The only comparable problems I can find on the net are rate of water leaking out of a hole in a bucket that is full with water (bernoulli's law). Can this equation be used too? Q = A x v?
A gas :eek: pipe with a 40 mm hole!*#?:eek:
Are you any relation to bob the builder?
hahaha yeah
why on Earth are you fixated on a water flow when you have a huge hole in a gas pipe ?
forget the water flow rate, it isn't important to your problem, turn it off and get the gas pipe fixed then get the water main fixed
Dave
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 32 ·
14K
