Can a small capacitor bank be used to power a robot with stable voltage?
The discussion revolves around the feasibility of using a small capacitor bank charged at 24 volts to power motors in a robot, specifically targeting voltages between 9 to 12 volts for operation. The conversation explores the implications of using capacitors versus batteries for energy storage and delivery in robotic applications.
  • One participant inquires about using a small capacitor bank charged at 24 volts to power robot motors.
  • Another participant suggests using current limiting resistors for charging but questions the choice of capacitors over batteries, noting that capacitors have limited energy storage capacity.
  • A participant explains their intention to use the capacitor bank in conjunction with a self-built generator, indicating a specific purpose for this setup.
  • It is proposed that supercapacitors might be suitable for short-duration energy storage, but batteries are generally preferred for longer durations.
  • One participant argues that capacitors are not ideal power supplies due to their inability to maintain stable voltage over extended periods, emphasizing that the voltage drops as current is drawn.
  • The same participant elaborates on the relationship between current, capacitance, and voltage change, asserting that a capacitor cannot provide stable voltage for powering devices like motors without significant capacitance.
Participants express differing views on the suitability of capacitors for powering a robot. While some suggest that capacitors can be used in specific contexts, others firmly argue that batteries are necessary for stable and sustained power delivery.
Participants highlight limitations regarding the energy storage capabilities of capacitors compared to batteries, as well as the need for understanding current requirements for motors. There is also an acknowledgment of the short duration for which capacitors can effectively supply power.
14shreyas
hi there,
i want to know that how can i use a small capacitor bank which can be charged with 24 volts and gives out the same, please help.
i want it to move motors for a robot like 9v to 12v each
You can use current limiting resisters in series to charge the capacitors.
But why do you want to use capacitors to move robot motors, why not battery? Capacitors can't hold much energy.
i want to use it for a purpose because i am running the robot on a generator i built myself, so the genrator will create electricity and charge the capacitor bank so i can use it afterwards. there is one more thing after this but i want to keep it a secret! ; )
You might use a supercapacitor to store little energy available over a short duration, but to supply power for over 10s or 100s batteries are better.
The thing about capacitors is that they are not ideal for using as power supplies. Their use is for filters, coupling and decoupling mostly. In digital systems they are used to power memory cells, but we are talking very, very short times (much less than a second).
A capacitor has a the relationship
[itex]i_{c} = C \frac{dv_{c}}{dt}[/itex]
Here, the current [itex]i_{c}[/itex] is the current running into the capacitor.
Rearranging the equation gives you
[itex]\frac{dv_{c}}{dt} = i_{c}/C[/itex]
As you can see, if the capacitor is used to supply a system (robot) the voltage will decrease. It is impossible to use a capacitor to power something (led, robot, resistor, whatever), for times longer than a few miliseconds or microseconds without the voltage changing rapidly.
So you can't charge a capacitor to 24 volts and then use it to provide a circuit with a stable 24 volts. The more current you use, the quicker the voltage goes down.
In conclusion: A capacitor is not use able as a power supply. You need to use batteries for this. Batteries can hold much more energy also, and they provide a stable voltage at their nodes.
Remember also, that if you want a power supply to run a motor, it is not enough to know the voltage it needs, you must also know something about how much current the motor needs to operate in the region you want it in.
IF you wanted to use capacitors to power your robot, you would need a very, very big capacitance. But again, the capacitor would not be able to provide a stable 24 volts. As soon as you begin tapping energy from it, the voltage drops.
  • · Replies 17 ·
  • · Replies 25 ·
