Estimate the number of electrons flowing in a semiconductor pn junction
The discussion focuses on estimating the number of electrons flowing in a semiconductor p-n junction with a drift current of 20μA. The initial calculation incorrectly assumes equal contributions from electrons and holes, leading to an estimate of 6.25 * 10^13 electrons per second. However, the correct approach requires separate calculations for each carrier type, considering their respective diffusion constants and concentrations, resulting in a total current that reflects a 3:1 ratio of hole current to electron current, yielding a corrected estimate of 3.125 * 10^13 electrons per second.
  • Understanding of semiconductor physics, specifically p-n junctions
  • Knowledge of drift current and its components
  • Familiarity with charge calculations involving electrons
  • Concept of carrier concentrations and diffusion constants
  • Study the principles of semiconductor doping and its effects on carrier concentrations
  • Learn about the diffusion constants for electrons and holes in p-n junctions
  • Research the impact of minority carrier lifetimes on current calculations
  • Explore the mathematical derivation of drift current in semiconductor devices
Electrical engineers, semiconductor physicists, and students studying solid-state electronics who seek to deepen their understanding of current flow in p-n junctions and related calculations.
nishantve1
The drift current in a p-n junction is 20μA . Estimate the number of electrons crossing a cross section per second in the depletion region.
Drift current is the current that occurs due to formation of holes and electrons in the depleted region from where the electrons and the holes are sucked away to the respective sides . This creates a current from n to p . Called the drift current The drift current is a result of flow of both holes and electrons.
So the electrons and the holes both equally contribute to the drift current . So the current due to the electrons would be 10μA . So that means
10 * 10^(-6) C flowing per second
charge on one electron = 1.6 * 10^-19 C
so we can write
n * 1.6 * 10^-19 C =10 * 10^(-6)
n = 6.25 * 10^13 electrons .
But the answer given is 3.125 * 10 ^ 13 , half of what I calculated .
Where am I wrong ?
I post this mainly since no one else has; it's not my specialty:
You can't assume that half the charges are electrons & the other half holes.
Each carrier current must be computed separately based on the respective charges' diffusion constants, minority carrier concentrations, and diffusion lengths (lifetimes); all figure separately for electrons and holes. Finally, you add the two to get the total junction current.
If the problem assumes equal n and p doping levels then one or more of the above parameters is such that the respective parameter ratio for holes & electrons accounts for the 3:1 ratio of hole current vs. electron current.
  • · Replies 18 ·
