| New Reply |
Micro USB OTG cables |
Share Thread | Thread Tools |
| Jan10-13, 01:51 PM | #1 |
I'm looking at getting one of these for my tablet but would a female to female USB adapter on the end of the USB lead that came with my tablet work the same?
Thanks |
| Jan14-13, 05:57 PM | #2 |
Admin
From what I've read you do indeed need the OTG cable. It is a standard.
| Jan14-13, 09:56 PM | #3 |
Recognitions:
Yup, you need the OTG cable.
In the beginning when things were simple, every USB device was built either as a "master" or a "slave" device, depending on what it did. For eaxmple a desktop computer would be a "master", but a memory stick or a USB printer would be a "slave". A network of USB devices only works properly if there is exactly one "master" device. That simple "master/slave" idea doesn't work with devices like tablets, which might sometimes need to function as a master and sometimes as a slave. The OTG cable fixes the problem by by making one end of the cable look like the master device and the other end like a slave, independent of what devices the cable is plugged into. In other words, you can connect "anything to anything" and it "just works." |
| New Reply |
| Thread Tools | |
Similar Threads for: Micro USB OTG cables
| Masses connected by cables - Tension in cables? | Introductory Physics Homework | 8 | ||
| coaxial cables | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Tension in Cables | Introductory Physics Homework | 3 | ||
| Tension in 3 cables | Introductory Physics Homework | 4 | ||
