Quantitative way to compare theoretical values to experimental values
This discussion focuses on comparing theoretical models to experimental values in the context of analyzing the cross-sectional shape of a sagging membrane. The primary method suggested for assessing model fit is the chi-squared test, which can be enhanced by scaling the sum of squared deviations by either the maximum sag or the area-averaged sag. An area-weighted square deviation divided by the area is also recommended for more accurate comparisons, particularly when dealing with non-uniform surface areas. The conversation emphasizes the importance of understanding discrepancies between predictions and observations in theoretical modeling.
  • Understanding of chi-squared tests in statistical analysis
  • Familiarity with sum of squared deviations in model fitting
  • Knowledge of area-weighted calculations for data analysis
  • Basic concepts of theoretical modeling in physics or engineering
  • Research the application of chi-squared tests in model validation
  • Explore techniques for calculating area-weighted deviations
  • Study the implications of non-uniform surface areas in experimental design
  • Investigate common discrepancies between theoretical predictions and experimental results
Researchers, engineers, and data analysts involved in experimental modeling and validation, particularly those working with physical systems and shape analysis.
Whiteblooded
I am looking at the cross-sectional shape of a sagging membrane. I have several theoretical models, neither of which fit perfectly. So rather than comparing values, I'm comparing shapes. One model fits fairly well, however I'm unsure of which quantity is correct to specify a 'goodness' of a model.
I'm thinking of some sort of sum of squared deviations (the quantity which least-squared fits minimises). The main problem with this is that the sum of squared deviations on its own will not really tell us about how good the fit is - I think I'll need to divide it by something else?..
You can scale either by the maximum sag, or by the area averaged sag. This will give you a much better shot at comparing the shapes. I would also recommend an area weighted square deviation, divided by the area (in case you are not using equal areas for the elements of surface). The big question is "why don't the predictions and observations match quantitatively." Another question would be "why would there be different theoretical model predictions to the same problem?"
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 62 ·
13K
