Point Where Electric Field=0 (3 point charges on x-axis)
The problem involves three point charges located on the x-axis, specifically -7 µC at x = -1.0 cm, 1.0 µC at x = 0, and +7 µC at x = +1.0 cm. The objective is to find a point on the positive x-axis where the electric field is zero.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to set up the equation for the electric field and seeks confirmation on their approach. Some participants suggest manipulating the equation to isolate x and consider using the quadratic formula, while others question the effectiveness of this method.
The discussion is ongoing, with participants providing tips on simplifying the equation by discarding common constants and focusing on the numerator. There is acknowledgment of a potential error in signs, and one participant notes the existence of a root between 0 and 1.
Participants are navigating the complexities of the equation setup and the implications of their manipulations, indicating a need for careful consideration of mathematical operations and assumptions about the electric field behavior.
lola748
Point charges of -7 µC, 1.0 µC, and +7 µC are located along the x-axis at x = -1.0 cm, x = 0, and x = +1.0 cm, respectively. Locate a point on the positive x-axis where the magnitude of the electric field is zero.
E=(kQ)/r^2
E(total)=E(1)+E(2)+E(3)
I feel like I have the correct setup of the equation and just wanted to confirm:
E=0=-(7e-6/(x+1)^2)+(1e-6/(x^2))-(7e-6/(1-x)^2)
From this point I'm not really sure on how to proceed with solving for x.
You need to isolate the x, so you should multiply out the exponent and rearrange the problem in order to use the quadratic equation.
Edit: Actually don't isolate the x, just multiply the exponents out and group the similar exponents out.
Edit 2: Hmm, its not working for me, disregard post
Tip: When you're looking for zeros, you can discard all the common constants (same as setting your equation to zero and dividing both sides by the common constants). So your equation then looks like:
$$0 = \frac{-7}{(1 + x)^2} + \frac{1}{x^2} + \frac{-7}{(1 - x)^2}$$
Putting that over a common denominator and taking just the numerator yields a function that doesn't look promising for having positive real roots.
Edit: I take that back! I made a silly sign error on the last term (now fixed). There is a root betwixt 0 and 1.
Aaaaah I see, Thank you!
  • · Replies 32 ·
