How Does Periodic Potential Affect the Energy Spectrum of a Bose Gas?
The discussion focuses on the effects of a periodic potential on the energy spectrum of an ideal Bose gas. The eigenstates are modified from the free-particle form, with the energy expression given by εk = 2t(2 - cos(kxa) - cos(kya)), where t is the energy scale related to the periodic potential amplitude. The density of states g(ε) is established to be zero for ε > 8t and ε < 0, while at low energies (0 ≤ ε << 8t), g(ε) approximates to L2/4πta2.
  • Understanding of Bose-Einstein statistics
  • Familiarity with periodic potentials in quantum mechanics
  • Knowledge of Brillouin zones and wavevector restrictions
  • Basic concepts of density of states in solid-state physics
  • Study the derivation of the density of states for two-dimensional systems
  • Explore the concept of Brillouin zones in greater detail
  • Learn about the implications of periodic potentials on quantum systems
  • Investigate the relationship between energy bands and wavevector distributions
Physicists, particularly those specializing in condensed matter physics, quantum mechanics students, and researchers studying Bose gases and their properties in periodic potentials.
physicus
Suppose an ideal bose gas sees a periodic potential with a period a in both x and y directions. Its eigenstates are altered from the free-particle form. The lowest band has energies
[itex]\epsilon_\vec{k}=2t(2-cos(k_xa)-cos(k_ya))[/itex]
where t is an energy scale that depends on the amplitude of the periodic potential, and the wavevectors [itex]\vec{k}[/itex] are restricted to the first Brillouin zone: [itex]\pi/a <k_{x,y}<\pi/a[/itex].
(i) Show that the density of states [itex]g(\epsilon)[/itex] is zero for [itex]\epsilon>8t[/itex] and [itex]\epsilon<0[/itex]
(ii) Show that [itex]g(\epsilon) \simeq L^2/4\pi ta^2[/itex] at low energies [itex]0\leq\epsilon\ll 8t[/itex]
Hint: Sketch the dispersion relation above consider the approximate form of [itex]\epsilon_{\vec{k}}[/itex] at lom wavelengths ([itex]ka \ll 1[/itex]).
Number (i) is quite obvious since the cosine can only take values between -1 and 1. Therefore the expression in brackets can only take value between 0 and 4 which shows that there are no states with energies < 0 or energies > 8t.
(ii) For long wavelengths we can approximate
[itex]\epsilon_\vec{k}=2t(2-cos(k_xa)-cos(k_ya)) = -2t(k_x^2 a^2+k_y^2a^2) = -2ta^2\vec{k}^2[/itex]
But how does that help me to get the density of states? I don't know how to begin. Can someone give me an ansatz?
Cheers, physicus
Check your result for your approximation of [itex]\epsilon_\vec{k}[/itex]. I think you might be off by a sign and a factor of 2.
To proceed to the density of states, compare your approximate result for [itex]\epsilon_\vec{k}[/itex] with [itex]\epsilon_{\vec{k},free}[/itex] for a free particle of mass m moving in 2 dimensions.
  • · Replies 16 ·
