Why does precession occur in Muon Spectroscopy?
  • Context: Graduate
  • Thread starter Thread starter Christopher Small
    Muon Spectroscopy
Precession in Muon Spectroscopy occurs due to the misalignment of the muon spin with the external magnetic field. When 100% polarized muons are fired at a sample, their decay emits positrons preferentially based on the muon's spin orientation at the time of decay. If a muon decays too quickly, it does not precess and emits positrons into the backward detector. Conversely, if it has a longer lifetime, it precesses, leading to positron emission into the forward detector, providing insights into the magnetic properties of materials.
  • Understanding of Muon-Spin Rotation (muSR) techniques
  • Familiarity with magnetic fields and their effects on particle spins
  • Knowledge of particle decay processes, specifically muon decay
  • Basic principles of spectroscopy and its applications in material science
  • Research the principles of Muon-Spin Rotation (muSR) in detail
  • Study the effects of external magnetic fields on particle spin orientations
  • Explore the differences between muon spectroscopy and neutron scattering techniques
  • Investigate the implications of muon lifetime on experimental outcomes in muSR studies
Physicists, materials scientists, and researchers interested in advanced spectroscopy techniques and the magnetic properties of materials.
Christopher Small
I've been doing some research on Muon spectroscopy, and am not that far in the physics world yet. I've got kind of a fuzzy picture of what goes on, but could use some help in identifying some key concepts. The information I have been getting is from the following paper
Muon-Spin Rotation Studies of Electronic Properties of Molecular Conductors and Superconductors
Stephen J. Blundell
Department of Physics, Oxford University, Clarendon Laboratory, Parks Road, Oxford OX1 3PU, United Kingdom
Received March 16, 2004
which I received from the American Chemical Society Data Base
What I have found thus far is that 100% polarized muons can be fired at a sample under study, and that the magnetic environment at the time of muon decay can have an effect on the emittance of positrons. Of prime importance to the theory of this form of study is the
propensity for the emitted positron to emerge predominantly along the direction of the muon spin when it decayed... the muon enters the sample with its spin pointing along the direction from which it came. If the muon is unlucky enough to decay immediately, then it will not have time to precess and a positron will be emitted preferentially into the backward detector. If the muon lives a little longer, it will have time to precess; therefore, for example, if it lives for half a revolution, the resultant positron will be preferentially emitted into the forward detector. Thus, the positron beam from an ensemble of precessing muons can be likened to the beam of light from a lighthouse.
Now my understanding is that since the muon has negative helicity, the spin axis points antiparallel to the direction of motion. Why does precession occur? Can anyone help clairify this or suggest a good resource?
Thanks
Thanks
The precession occurs because the muon spin is not along the direction of the external magnetic field that the muon is in. This is why, if the muon decays too quickly to "sample" the surrounding field, it will not have time to precess.
However, in most cases, the muon lifetime is long enough (some people think it is too long and that's why neutron scattering is used in the study of many other materials) that the muon spectrum in a typical muSR spectroscopy will provide more of an "average" information of the magnetic orientation of the material being studied.
Zz.
  • · Replies 0 ·
  • · Replies 20 ·
  • · Replies 50 ·
13K
  • · Replies 27 ·
