What is the largest SMD value that is required to sustain combustion.
  • Thread starter Thread starter sgvaibhav
    Combustion Value
The largest Sauter Mean Diameter (SMD) required to sustain combustion in a gas turbine engine using kerosene as fuel is critical for effective ignition. Larger droplets necessitate higher ignition energy and potentially longer ignition times. The atomizer pressure directly influences droplet injection velocity, affecting the effective ignition energy. For setups with atomizers producing larger droplets, increasing the SMD by 10% can require 3-4 times more ignition energy to maintain combustion.
  • Understanding of Sauter Mean Diameter (SMD) and its significance in combustion.
  • Knowledge of gas turbine engine operation and fuel injection systems.
  • Familiarity with ignition energy requirements and their relationship to droplet size.
  • Experience with atomizer pressure adjustments and their effects on fuel mixture.
  • Research the impact of droplet size on ignition energy in gas turbine engines.
  • Study the relationship between atomizer pressure and droplet injection velocity.
  • Explore methods to optimize SMD for efficient combustion in gas turbines.
  • Investigate advanced atomization techniques for kerosene fuel in gas turbine applications.
Engineers, fuel system designers, and combustion specialists focused on optimizing gas turbine performance and ignition efficiency.
sgvaibhav
Using kerosene as a fuel in a gas turbine engine.
What can be the largest SMD that the atomizers HAVE to provide for engine start-up and to sustain combustion?
SMD : Sauter Mean Diameter or also known as D32 in drop size distributions model.
This is a difficult question to answer. Some guidelines: if your droplets are larger, you need a higher ignition energy. Also, you might need to adjust the ignition time, which should be probably longer.
The effective ignition energy depends on the droplet injection velocity, so the atomizer pressure. When there's premixing, a fuel lean mixture will need more ignition energy.
So, if you have an existing setup with an atomizer producing too large droplets, then increase the ignition energy. For an existing and working setup, if you increase the SMD by 10% you'll easily need 3-4 times higher ignition energy.
  • · Replies 39 ·
17K
24K
