Calculating Max Power Dissipation & Current for 3.0-hp Pump, 240 V
  • Thread starter Thread starter Soaring Crane
    Currents Electric
The maximum instantaneous power dissipated by a 3.0-hp pump connected to a 240 V AC power source is 2238 W, equivalent to 3 hp. The maximum current passing through the pump is calculated to be 9.325 A. The formulas used include P = I * V for power calculation and the conversion from horsepower to watts using the factor of 746 W/hp. Additionally, the peak current is derived as 13.2 A, indicating the maximum current the pump can handle without damage.
  • Understanding of AC power concepts, specifically RMS and peak values.
  • Familiarity with electrical formulas, particularly P = I * V.
  • Knowledge of power conversion between horsepower and watts.
  • Basic principles of electrical engineering related to pumps and motors.
  • Study the relationship between RMS and peak values in AC circuits.
  • Learn about the implications of power ratings in electric motors.
  • Research the design specifications for household pumps and their current ratings.
  • Explore advanced electrical calculations involving reactive power and power factor.
Electrical engineers, technicians working with pumps, and anyone involved in the design or maintenance of AC motor systems will benefit from this discussion.
Soaring Crane
What is the maximum instantaneous power dissipated by, and maximum current passing through, a 3.0-hp pump connected to a 240-V ac power source?
ANSWER: 6 hp, 13 A
Given:
P = 3 hp = 2238 W (1 hp = 246 W)
V = 240 V
I don't know which formula to use. At first, I attempted to use P = I*V, but, then, I got flustered over the provided formulas in my book. Peak current is mentioned, and there are different variations of P. Did I start off correctly? How am I supposed to execute this problem?
Thanks.
ANSWER: 6 hp, 13 A
Given:
V = 240 V
Standard electrical specifications for AC Current and AC Voltage are expressed with "RMS" ("Root Mean Square") values of the AC sine wave quantities. Standard AC Power specifications are expressed with "Average Power" given by {(RMS Voltage)*(RMS Current)}. Following equations convert these standard specifications to alternate specifications concerning other properties of the AC sine wave:
{Peak AC Voltage} = (1.414)*{RMS AC Voltage}
{Peak AC Current} = (1.414)*{RMS AC Current}
{Peak AC Power} = {Peak AC Voltage}*{Peak AC Current} =
= (1.414)*{RMS AC Voltage}*(1.414)*{RMS AC Current} =
= 2*{Average AC Power}
For this problem, following values are given:
{RMS AC Voltage} = (240 V)
{Average AC Power} = (3 hp) = (2238 W)
from which can be derived:
{RMS AC Current} = {Average AC Power}/{RMS AC Voltage} = (2238)/(240) = (9.33 A)
{Peak AC Current} = (1.414)*{RMS AC Current} = (1.414)*(9.33 A) = (13.2 A)
{Peak AC Power} = (2)*{Average AC Power} = (2)*(3 hp) = (6 hp)
Firstly, it is important to note that power is typically measured in watts (W), not horsepower (hp). In this case, we can convert 3 hp to watts by multiplying it by the conversion factor of 746 W/hp, which gives us a power of 2238 W.
Now, to calculate the maximum instantaneous power dissipated by the pump, we can use the formula P = I*V, where P is power in watts, I is current in amperes (A), and V is voltage in volts (V). Substituting the given values, we get:
2238 W = I * 240 V
Solving for I, we get:
I = 2238 W / 240 V = 9.325 A
Therefore, the maximum instantaneous power dissipated by the pump is 2238 W and the maximum current passing through it is 9.325 A.
However, since the pump is rated at 3.0 hp, it is likely that this power refers to its rated or continuous power, not its maximum instantaneous power. So, we can also calculate the maximum power dissipated by the pump using the formula P = hp * 746 W/hp. Substituting the given values, we get:
P = 3 hp * 746 W/hp = 2238 W
This confirms that the maximum power dissipated by the pump is indeed 2238 W.
In terms of peak current, it is likely referring to the maximum current that the pump can handle without causing damage. This would also depend on the specific design and components of the pump. However, in this case, the maximum current passing through the pump is 9.325 A, which is well below the typical peak current ratings for household pumps.
In summary, the maximum instantaneous power dissipated by the 3.0-hp pump connected to a 240 V ac power source is 2238 W and the maximum current passing through it is 9.325 A.
  • · Replies 28 ·
