Finding major species in aqueous solutions
The discussion focuses on identifying major species in various aqueous solutions, specifically examining NH4Cl, NaCH3CO2, HCN, HNO3, and the interaction between CH3CO2H and NaOH. The correct major species identified include NH4+, Cl-, H3O+, and NO3- for their respective solutions. The importance of using Ka values to determine dissociation of acids is emphasized, along with the recommendation to utilize the BATE tool for verification of calculations.
  • Understanding of acid-base chemistry and dissociation
  • Familiarity with aqueous solution chemistry
  • Knowledge of major ions in solution
  • Experience with using Ka values for acid strength
  • Research the dissociation constants (Ka) for common acids and bases
  • Learn how to use the BATE tool for acid-base calculations
  • Study the concept of spectator ions in chemical reactions
  • Explore the behavior of weak acids in aqueous solutions
Chemistry students, educators, and professionals involved in analytical chemistry or aqueous solution analysis will benefit from this discussion.
parwana
Which of the following are correct statements ?
a) In an aqueous solution of NH4Cl, H2O, NH4+ and Cl-are the major species present
b) In an aqueous solution of NaCH3CO2, H2O, Na+ and HCH3CO2 are the major species present
c) In an aqueous solution of HCN, H2O, H3O+ and CN- are the major species present
d) In an aqueous solution of HNO3, H2O, H3O+ and NO3- are the major species present
e) In a solution of CH3CO2H and NaOH, Na+ is a spectator ion
I know a should be right since those are ions, but don't know about the rest. Help
Chemistry news on Phys.org
You should look at the Ka values for all species and decide, whether acids are dissociated or not. That's the main point.
Try BATE for these calculations - while you should be able to make them by yourself it can help check the results :wink:
17K
