How do electrons keep out of the nucleus?
  • Context: Undergrad
  • Thread starter Thread starter penguinraider
    Electrons Nucleus
The discussion revolves around the question of why electrons do not collapse into the atomic nucleus, exploring concepts from quantum mechanics, atomic structure, and the nature of electron behavior. Participants examine various models and analogies, including the comparison of atomic structure to planetary orbits, while addressing the implications of potential and kinetic energy in electron stability.
  • Some participants suggest that inertia and a nucleus's "gravity" are factors preventing electrons from being attracted to protons.
  • Others argue that gravity is negligible in atomic interactions and that quantum mechanics provides the necessary framework for understanding atomic stability.
  • One participant describes the balance of potential and kinetic energy as crucial to preventing electrons from falling into the nucleus, noting that electrons in orbitals have specific velocities.
  • Another participant emphasizes the need for a quantum mechanical explanation for why electrons do not radiate while in atomic orbitals, questioning the use of classical analogies.
  • Some contributions highlight the distinction between viewing electrons as particles versus waves, arguing that electrons do not have well-defined positions until measured.
  • A participant challenges the analogy of electrons orbiting the nucleus like planets, asserting that this misrepresents atomic structure.
  • There are claims about the correctness of quantum mechanics, with some participants asserting that it is filled with inaccuracies while others defend its validity.
  • Disagreements arise regarding the nature of electrons and the interpretation of quantum mechanics, with calls for sources to substantiate claims made.
Participants express multiple competing views on the nature of electrons, the applicability of classical analogies, and the validity of quantum mechanics. The discussion remains unresolved, with no consensus reached on several key points.
Participants reference various models and analogies, but there is a lack of agreement on their appropriateness. The discussion also reflects differing interpretations of quantum mechanics and the implications of electron behavior, highlighting the complexity of the topic.
penguinraider
Apart from inertia and a nucleus' "gravity" (I invisage it's like the planets revolving around the sun), are there any other factors that keep the electrons from being attracted to the protons and crushing into the nucleus?
Gravity doesn't contribute with (almost) nothing.It can be totally neglected.The model with planets orbitting the Sun it's good for planets orbitting the Sun,it's perfectly useless (due to incorrectness) in atomic description.
The laws of Quantum Mechanics (its axioms & results) applied to the atom give all the proof needed for atomic stability.
Daniel.
Here is how you should look at the fact that electrons do not crash onto the atomic nucleus and why they don't radiate : there is no radiation of electrons in an atom. The electrons move indeed in orbitals with a certain velocity (no acceleration). Now the fact that electrons do not fall into the nucleus due to the Coulombic interaction has to do with the fact that there is an equilibrium in both potential and kinetic energy.
Electrons that are "closest" to the nucleus have a lower potential energy (more negative) but they move in the orbitals with higher speed (higher kinetic energy). Once you look at electrons further waway from the nucleus, the potential energy rises and the velocity (and therefore the kinetic energy) lowers. In the end there is an equilibrium between those two.
marlon
marlon
We should be careful. Accelerating a charge is not enough to produce
radiation. If it were, then electrons at rest in a gravity field would radiate since they are being constantly accelerated.
Furthermore, atomic quantum orbitals are anything but constant velocity
configurations, since a change in either direction or speed implies acceleration.
A better answer is needed for why electrons don't radiate in atomic orbitals,
and it is a purely quantum mechanical explanation (which I myself am still looking for.)
Well, since we are trying to "be careful" here, let's also make sure we be extra careful in saying that the atomic orbitals somehow implies a "velocity" or speed of anything. It doesn't. By saying such things, we are already implicitly implying a well-defined charged particle moving around. You don't have such things until a position measurement is done. Before then, an electron in an s-orbital, for example, has no well-defined position and identity. Rather, based on the wavefunction alone, it is "spread out" in a uniform sphere around the nucleus. So the electron is everywhere simultaneously (which is connected to the Schrödinger Cat-type puzzlement - another illustration that things in QM are interconnected). This is how we get an angular momentum of zero for the s-orbital - from the geometry of the orbital itself.
This is another illustration where our social language can cause many confusion in trying to describe things that have no linguistic equivalent. As soon as we say "electron moves in an orbit", a whole range of implications kick in. We automatically imply that there is this well-defined object that we can track along the way and moving in a well-defined trajectory. QM implies no such thing, at least as far as atomic orbitals are concerned. We have seen a whole zoo of evidence where an "electron" can simultaneously spread itself into many locations to produce unclassical effects (bonding-antibonding bands, etc.) .
Zz.
Well, indeed maybe i shoudn't have written constant velocity...That is indeed not correct. But the point really is the equilibrium between potential and kinetic energy.
marlon
elctric field is the answer...the protons are positive
the elctron are negative
if the elctron were putted in a right place and shooted in a right velocity it will orbit the proton and never hitting it
..by the way
its a bad example saying that the atomic structure are like planets
its not right to say that the elctrons orbiting the nucleas is like planets revolving around the sun
the elctron was thoght a particle but sceintests discoverd that it is a wave
its true
qm quantum meachanicks is filled with uncorrect statics
but it helped a lot for understanding the atomic srtucture
..by the way
its true
I think those are false claims...If u have a source to document your affirmation,please,post them and i'll accept it/them.
Till then,please,do not post erroneous claims...
Daniel.
P.S.It would help your cause a lot,by spelling English properly.We have a spell checker,in case u haven't noticed...
ok danial
first of all sorry i am a bad speeler and that won't change
second its true i never tell lies i always make sur iam right
and these are the sites so you can make sur for your own self
http://www.telp.com/qw1.htm
http://www.rit.edu/~photo/IFS/index-pages/IFS-20.html
http://www.colorado.edu/physics/2000/index.pl
1.Electron is not a wave.
2.Quantum Mechanics "is filled" with correct descriptions of nature.
There's a giant thread in the QM & QFT forum about "What's wrong with QM?".Maybe you'd like to share your views with us.Who knows,we might learn something...
Waiting you there,
Daniel (sic!).
P.S.Good thing it's not "denial" :
nebulan said:
ok danial
link 1 doesn't explicitly say electrons are waves.
link 2 uses a bad wording.
link 3 doesn't explicitly say electrons are waves.
its true
How does a wave have a spin? I know an electron does.
its wave are collided to a ball shape
A physicist named Erwin Schrödinger showed that electrons are really waves
check this scientest Erwin Schrödinger and youl know that an elctron is a wave
The classical equivalent of photon spin is what we call independent polarization directions of an em wave.Incidentally,in QFT,when describing a photon,we use the wording "polarization states" when talking about helicity eigenstates of the photon...
Daniel.
wow. how did you reach this conclusion from schrödinger's formulation of quantum mechanics?
A correct description of the concept of "electron" is offered by the quantum theory of the Dirac field.Period.
Daniel;
the problem is no field of science has ever explicitly stated whether or not and showed logically how, a field is not made up of mass, matter. To say a field can exist in of itself is to say that energy can exist without mass. Its also to imply that F=ma is wrong, as well as, E=mc^2 because both these formulas indicate that a field must actually be comprised of particles (mass, matter) - that energy and mass cannot exist without each other.
I really wonder where people keep getting the idea that an electron is a field. Especially in QFT ?
marlon
The electron is a quanta of the electron field:a Grassmann [itex]\left(\frac{1}{2},0\right)\oplus \left(0,\frac{1}{2}\right)[/itex] irreductible representation of [itex]\mbox{SO(3,1)}[/itex] to which certain conditions are imposed (see the solving of Dirac's equation for free field).
Daniel.
Daniel.
Yes and every good student should ask the question : WHY ?
Well, the answer is once again group theory.
When studying the Lorentz group (the group that arises when you 'add up' both rotations and Lorentz boosts) one can prove that the generators will obey certain commutation relations conform the SO(3,1)-algebra.
When studying this algebra we can prove that (by writing these generators in a 'certain' way : J+, J-) [J+,J-] = 0. This results tells us that the representations generated by these two operators are 'independent' of each other. More formally, the SO(3,1) breaks up into two SU(2)-algebra's. Why SU(2), well that's because of how J+ and J- are defined (which we won't discuss). Just imagine that the two operators obey the rules 'for belonging to this SU(2)-algebra'
Basically this means that once you know the SU(2)-representations, you also know the SO(3,1)-representations. The generators of these algebra's are the famous Pauli-matrices.
Each SU(2) representation is denoted by a number j which has values 0,1/2,1,3/2,...and it contains 2j+1 objects [tex]\phi _{m}[/tex] (and m is equal to -j,-j-1,...,0,1,...,j) that transform into each other under such transformations generated by the Pauli-matrices.
For SO(3,1) we need two such j's : (j+,j-) and the representations are (0,0), (1/2,0), (0,1/2), (1,0),...
The (1/2,0) and (0,1/2) are the socalled spinor representations. If have explained what a spinor is, in my journal.As you can see, a spinor has two components (2*1/2+1) and can be represented by a 2*1-matrix ([tex]\phi_{1,2}[/tex], the component-notation of such a matrix). But Dirac proved (when quantizing the Dirac field of which the fluctuations are the electrons) that the 'correct' spinor (that describes an electron) needs 4 components. Why ? Well, because of parity conservation. The two representations that we are talking about are interchanged when parity is changed. Thus we work with BOTh representations at once : this is what dexter wrote in his post : (1/2,0) + (0,1/2). We basically put two (Weyl)spinors together to form a Dirac spinor.
regards
marlon
Besides, i would like to add this : people always ask how do electrons orbiting the nucleus prevent from falling in ? Well, this question itself contains incorrect formulations. the electron does NOT orbit the nucleus. Just look at the lowest energy orbital : the s-orbital. It is a sphere around the nucleus. So , prior to any kind of measurement, the electron is basically everywhere around the nucleus.
Same goes for any other orbital (ofcourse the have another shape)
QM proves us that the kinetic energy is higher when being closer to the nucleus, but the potential energy is lower (more negative). The sum of these two really yields a stable equilibrium throughout all energy levels.
marlon
And finally (then i will stop whinning) people always mix QFT with QM. A wave function that describes an electron is not a wave that IS an electron. It just contains the electron-properties. This is QM
In QFT, particles arise as fluctuations of fields but the fields themselves ARE NOT particles. Particles arise (and also forces) as actual vinrations of these fields. Just think of the mattress analogy that i have used throughout my entire journal
regards
marlon
Yes but that is the very problem QM and QFT are in disagreement. As well QFT never actually explains how its possible for particles to arise out of fluctuations of fields. Also, it never explains how fields exist without being comprised of particles, basically it never offers a formula, that is consistent with reality, and that shows force can exist without mass, particles.
The concept of quantization itself turns classical fields into quantum fields.What's so particular about these quantum fields ?The fact that their energy is quantized and appears under the form of particles...
As for
That's simply bull****.
Daniel.
Really, as far as I know its not bull but I may be just lacking education on this matter. If it is bull could you please please post the formula(s) that it offers to prove this.
I think you have to prove your statement...
Daniel.
i didn't make a statement to prove. All i said was that as far as i know, there are no formulas in QFT that prove force can exist without mass or that energy can exist without mass. If there are can you please post them so i will be corrected.
Look, i am not going to argue with you but clearly your understanding of QFt is totally wrong. QM is incorporated in QFT. QFT really is the 'unfication' of both QM and special relativity. You don't have to believe me, just ask anyone else or read Anthony Zee's book QFT in a Nutshell.
As to the fluctuations : just google for the Casimir effect, which is a REALTIME prove that such fluctuations must exist.
regards
marlon
  • · Replies 29 ·
  • · Replies 56 ·
