Race Between Light and Runner: Who Wins?
The discussion revolves around a thought experiment involving a race between a runner (hypothetically able to run at light speed) and light itself, exploring concepts of speed, reference frames, and the implications of relativity. Participants examine the outcomes from different perspectives, including those of an observer and the runner, while addressing the complexities of time dilation and length contraction.
  • Some participants propose that if a runner could travel at light speed, both the runner and light would reach the finish line simultaneously from the observer's perspective, but the runner would perceive light traveling faster than himself.
  • Others argue that it is impossible for a material object to travel at the speed of light, thus rendering the original scenario moot.
  • A participant suggests that if the runner travels at 90% of light speed, the observer would measure the runner taking longer to finish compared to light, while the runner would perceive the distance to the finish line as contracted.
  • Some participants clarify that the runner's clock runs normally, and the perceived time for light to cross the finish line would differ based on the reference frame used.
  • There are discussions about the implications of Lorentz contraction and how different observers would measure time and distance differently.
  • A later reply introduces a new scenario with multiple runners, questioning whether they would all agree on the timing of light crossing the finish line, highlighting the relativity of simultaneity.
Participants generally disagree on the feasibility of the original scenario of running at light speed and the implications of relativity. Multiple competing views exist regarding how time and distance are perceived by different observers, and the discussion remains unresolved on several points.
Participants express uncertainty about the application of relativistic concepts, such as time dilation and length contraction, and how they interact with the notion of simultaneity across different reference frames.
This discussion may be of interest to those exploring concepts in special relativity, particularly in understanding the implications of speed, reference frames, and the nature of simultaneity in different contexts.
Razor436
I found it interesting when i learned that no matter how fast you are traveling through space, you will alwys measure light to be traveling at the same speed. Then I thought of something:
What would happen in this situation.
There is a race. The two racers are me, wearing my "light speed" shoes that let's me run at the speed of light, and the other racer is light itself. Watching this race is the observer Karl.
The distance to run is a light minute. (ie the distance light travels in a minute).
Who wins the race?
This is what I think, and it seems kinda strange.
Karl sees both me and light traveling at the same speed and we both reach the finish line at the same time (in one minute).
On the other hand, I, the runner, know that i am running at the speed of light but while I am running, i measure light to travel at light speed with respect to my frame of reference. So although the runner reaches the finish line 1 minute after the start of the race, light fininshes the race in a fraction of a second in the runner's point of view.
That's why you can't travel at the speed of light: if your traveling at the speed of light, it is impossible for light to travel at the speed of light with respect to you. In the contrary this is possible (and sensible) if you travel at a speed lower than that of light.
It's a moot question that been asked many times. You cannot run the speed of light, even in a thought experiment.
- Warren
That is not the point of my question.
Let us say, instead that the runner is traveling at 90% of light speed.
Then the observer observes the runnertaking 1.11 minutes to reach the finish line, while light took 1 minute.
On the other hand, in the runner's point of view, he reaches the finish line in 1.11 minutes but light sped right past him at light speed and reached the finish line in much less than 1 minute.
My point is that as the runner gets closer to light speed (he does not actually have to reach light speed), then the observations made by the runner and the observer regarding how long it took light to cross the finish line, seem to contradict each other
No, he doesn't. For him the distance between start + finish lines is contracted, but the finish line still approaches him at 0.9c. He sees a distance of 0.435 light minutes between the two lines. So he observes the light completing the race in 0.435 minutes (about 26 seconds), and himself finishing in 0.484 minutes (about 29 seconds).
That's false. The observer will always see his own clock running normally. What some other observer measures is irrelevant to him.
I sense that you have some misconceptions about how to figure time dilation. If you'd like to make the scenario precise (give me the distance of the track and so on), I can show you precisely what every observer will see.
...seem to contradict each other
It only seems that way because you are mixing reference frames; in other words, you aren't working the problem properly.
- Warren
Apply the Lorentz contraction, very simple.
Razor436 said:
The two racers are me, wearing my "light speed" shoes that let's me run at the speed of light, [...]
In relativity theory, it is impossible for a material object to move at the speed of light. Therefore your paradox is impossible to set up in the first place.
I had a feeling when I read the original post that he'd get a barrage of "You can't move at light speed!", but the problem is posed in such a way that this is mainly a semantic point. The real confusion, as chroot says, is in the reference frames. You can look at it two ways:
1) The runner is moving at 0.9c relative to the stationary finish line. From the point of view of an observer waiting at the finish line, it does take 1.11 minutes for the runner to arrive and 1 minute for the light. However, moving clocks always run slower, so from the point of view of the runner, it takes less time to get there, both for him and for the light (0.484 and 0.435).
2) The runner is moving at 0.9c relative to the stationary finish line. From the point of view of the runner, the distance to the finish line (coming at him at 0.9c) is contracted to less than a light minute, so it takes less time than that to get there, both for him and for the light.
Either description is valid, though I'm not sure which is easier to think about. The key thing to remember is that time dilation and length contraction are complementary concepts. The constancy of the speed of light requires one in the presence of the other.
And don't forget the relativity of simultaneity--a lot of people get confused on these problems because they take into account Lorentz contraction and time dilation but they forget about (or don't know about) the fact that different frames define simultaneity differently.
A good point and yet another reason why spacetime diagrams are the preferred means of understanding SR.
:confused: I thought this was pretty unambiguous:
On the other hand, I, the runner, know that i am running at the speed of light [...]
OK, now I see that he rephrased his question later to 90% of light speed. I was fixating on the original question.
Thnx for all your replies.
I'd like to ask another question to make sure I understand this topic well.
Lets imagine a similar race.
In this race, there are 10 runners. Runner1 runs at 10%lightspeed, Runner2 at 20% of lightspeed, ... Runner9 at 90% of lightspeed, and the 10th runner is light itself. And Karl is watching the race in the stands.
Here is the important part: The 9 runners and the observer Karl are to raise a flag they have with them (a signal) when they see light cross the finish line.
Lets see if i understand this: I think all runners and the observer will disagree on how much time it took light to cross the finish the finish line and how much distance the light had to travel to reach the finish line. However, The 9 runners and the observer will raise their flags simultaneously.
Do i have that right?
Remeber what JesseM said? Simultaneity is defined different in different frames. So there is no meaning in your statement (as long as you don't mention according to who the flags are raised simultaneously).
And if each runner raises his flag when he sees the light cross the finish line in his own frame, then in each runner's own frame all the other runners will raise their flags at different times.
Last question (promise)
Imagine this situation.
There is a car race. The car we are interested in travels at 90% lightspeed. To this car is attached a camera so we kinda have a view of what the driver sees (like in a car race on TV). The videa from the camera is broadcast live on TV.
An observer is at the race in person and also has a TV next to him, watching the footage from the camera on the car.
In the observer's frame, does he see the car cross the finish line first in real life or on tv or do they happen at the same time?
It depends on the path the TV signal takes. Does the signal go from the camera directly to the observer at the race - or does it go to the TV truck, then to the broadcast studio (possibly via a satellite link), then back to the viewer?
If the TV signal takes a direct path, they both should arive at about the same time, as the TV signal travels as the same speed that light does. If the TV signal takes an indirect path (very likely), it will arive later than the light.
Note that what a person sees is not the Lorentz transformation, but the Lorentz transformation plus associated speed-of-light signal delays. Search some of the past physics forum threads for "Terrel rotation" for some of the technical details of what an observer sees. There's a website which has educational videos which show what sort of visual relativistic effects an observer would see if the speed of ligh were very slow (you can also think of this as what an actual observer would see if he played the video back in slow-motion, as watching someone travel a mile traveling at 90% of the speed of light takes 5 microseconds, not enough time to enjoy the show.
- Warren
Funny, my thought experiments DO let me run this fast. It's just
that they can never become physical experiments.
Albert Einstein had this very thought experiement when he was coming up
with special relativity (only he thought of trains instead of tennis shoes.)
What chroot means is that (in special rleativty) it is not just practically impossible, but theoretically impossible, so the only thing that physics tells us about running at light speed is that we can't do it.
Indeed.
If you want to make a thought experiment about running faster than light, you're ipso facto no longer working with special relativity, which is the mainstream theory describing high-velocity motion, because running faster than light is not possible in that theory.
If you're no longer working with special relativity, who knows what theory/model you're working with? It could be anything at all, as fanciful as you like -- but then your question still has no definite answer, and the discussion doesn't belong on this site, anyway.
- Warren
chroot said:
Indeed.
- Warren
You are all correct of course.
I was merely making the point that in a thought experiment, *anything* is
allowed. I can easily imagine running at the speed of light. If I am good
at the thought experimenting though, I will quickly conclude that there are
serious problems like elapsed time and kinetic energy and the like.
When the young einstein was formulating special relativity he imagined
himself moving at the speed of light and asked questions about the physics
of it. This is thought experimenting at its best.
On the other hand, Antiphon, good thought experiments are always done within the context of some model. Generally, a thought experiment follows these steps:
1) Define some axioms, or postulates, which form the basis of a model.
2) Consider many different situations, and determine what the chosen model predicts.
3) Compare the results of many such situations to find internal inconsistencies, absurdities, and other evidence that the postulates chosen in (1) cannot be correct in reality.
If you skip step (1), you're not really doing a thought experiment at all -- you're just rambling.
- Warren
- Warren
Agreed. When Einstein moved at the speed of light in his thought experiment,
he did it in the context of the known laws of electrodynamics but with the
postulate that there is not an upper limit on velocity. That was your step 1)
for him, and clearly he wasn't rambling.
I've got a meta-question. If someone posts something with a title that doesn't match the question they ask in the bulk of their question, should we ignore the title and respond to the question that was asked, or should we make a point of mentioning that the title doesn't match the question - or perhaps there is some third alternative?
This seems to come up a lot where people put a crazy-sounding title to a question that in and of itself is not unreasonable. For example, this thread. "Running at light speed", the title of this thread, doesn't make any physical sense. But if we go back to the top of the thread, the acutal question that was asked doesn't have anyone running at light speed, and is a fairly standard question involving objects that all travel less than 'c', plus some TV and light signals that travel at 'c'.
The theory of electrodynamics at the time also said that these laws would only hold exactly in a single frame (the reference frame of the 'luminiferous ether') and that in other frames they'd have to be modified by a Galilei transform--so even at speeds slower than light, this theory would make different predictions than relativity does (for example, if you moved at 0.4c relative to the rest frame of the ether, in your frame light would move at 0.6c in one direction and 1.4c in the opposite direction).
  • · Replies 26 ·
  • · Replies 93 ·
  • · Replies 51 ·
  • · Replies 42 ·
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 53 ·
  • · Replies 25 ·
