New Reply
Magnetic flux and C-EMF
Share Thread Thread Tools
Jan26-13, 03:36 PM   #1
A friend of mine told me that in order for Back-EMF to be generated,
The flux lines has to be parallel. Is that true?
This question is based on a electromagnet - magnet set up. The flux lines must be parallel?
At least C-EMF can be generated but if the flux lines are perpendicular it will not be significant as if they were in parallel.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan26-13, 04:11 PM   #2
mfb
Mentor
What has to be parallel to what?
Jan26-13, 04:20 PM   #3
A magnet's flux lines and an electromagnets flux lines.
Jan26-13, 04:41 PM   #4
mfb
Mentor
You don't need any current in the electromagnet to get a voltage there, so the magnetic field of the electromagnet does not have to exist, if the magnet is moving.
Jan26-13, 04:55 PM   #5
But generally does it matter if the flux lines are parallel or perpendicular?
Jan26-13, 05:32 PM   #6
mfb
Mentor
It does not even matter if there is a relative orientation, therefore: No.
The geometry of the magnet and the coil of the electromagnet matters, of course, but not in a way that you can say "x parallel to y = good!" or "x perpendicular to y = good!".
Jan26-13, 06:24 PM   #7
Quote by mfb View Post
Then in what way does the geometry matters? So the simplest way to answer my question is: No.
I need to ask my friend use to back this claim.
Jan27-13, 08:10 AM   #8
mfb
Mentor
In general, in a complicated way.
Jan27-13, 02:24 PM   #9
Why don't I need any current? Even if the magnet is moving? Could you explain.
Jan27-13, 03:21 PM   #10
Recognitions:
Gold Membership Gold Member
Quote by Miyz View Post
Hold on. If you set up an electromagnet - magnet combination, the flux lines from both magnets will either reinforce or cancel each other out. If you have like poles facing each other the lines get "flattened" at the pole since they can't cross each other, whereas if you have opposite poles facing each other the lines simply go from one magnet straight to the other magnet.
Let's say you turn your power to the electromagnet off. Then you move the permanent magnet in and out of the coil. You will generate both an EMF and a C-EMF in the coil based on the number of turns and the strength of your magnet. This is because the EMF induced in the coil causes current to flow. The current flow creates a magnetic field that cuts across the coil and induces a counter EMF that is opposite to your original EMF.
If you leave the power on and move the magnet in and out of the coil the same thing happens, as the magnetic field of the coil changes when you move the magnet in and out. This change in the field again induces EMF in the coil itself (seperate from the EMF from your power supply of the electromagnet), which causes a change in current flow, which causes a change in the magnetic field, inducing a counter EMF.
The key here is that no matter how your field lines are meeting, moving the magnet around changes the magnetic field in the coil in some fashion. This change generates all the EMF and C-EMF, which again is separate from the EMF provided by your power supply to the electromagnet. The EMF from moving the magnet around may work with OR against your power supply, and the C-EMF always works against that induced EMF.
I'm sure that's about as clear as mud, so let me know if it doesn't make sense.
Jan28-13, 11:47 PM   #11
Quote by Drakkith View Post
In what why can it work WITH and in what why can it work against?
Could you explain more?
Aside from the question above everything is clear.
Jan29-13, 05:06 AM   #12
Recognitions:
Let's say you have DC current flowing through a coil creating a magnetic field. Moving a permanent magnet in and out will cause a voltage to be applied that opposes the current flow when the magnet is moved one way, and will work with the current flow the other way. It's exactly the same as if you had zero current flowing through the coil in that moving the magnet in and out produces an AC current. But since you had current flowing already you would just cause less or more to flow.
Jan29-13, 07:38 AM   #13
Very interesting point, this can be used to help me with my project! I can learn to work with C-EMF and the induced EMF, certainly I must study a lot of configurations...
Another thing, when a magnet goes in and out of a coil. It generates a higher quantity of EMF or C-EMF (depending if the coil was a electromagnet or not...).
But if the magnet was only near by, moved only to the tip of the coil/electromagnet it will not generate a significant EMF/C-EMF.
And I doubt the flux lines being parallel or perpendicular would matter at all...
Jan29-13, 04:25 PM   #14
Recognitions:
No, both EMF and C-EMF are always generated.
Jan29-13, 11:05 PM   #15
Ow sorry, had to re-read your finally post and figured out what I forgot to add " BOTH emf and c-emf are generated."
But still, they are highly generated if the magnet's field passes fully through the coil? In other words, if the magnet passes through the coil completely. But if it only comes to the tip, its less than going through.
Jan30-13, 05:10 AM   #16
Recognitions:
Of course. If you just wiggle the magnet around 5 feet from the coil you'll barely do anything since the strength of the field has dropped off significantly.
Jan30-13, 10:34 AM   #17
Or to be more specific here is what I mean by close by not going through the coil.
New Reply
Thread Tools
Similar Threads for: Magnetic flux and C-EMF
Thread Forum Replies
What is magnetic flux and magnetic flux density? Please keep it simple. Introductory Physics Homework 3
Differences between Electromagnetic flux and magnetic flux Classical Physics 3
Hall Effect Magnetic Flux Sensor in very Strong Magnetic Fields Electrical Engineering 17
magnetic flux density vs magnetic flux Classical Physics 5
Magnetic fieldstrength, magnetic flux, magnetic flux density General Physics 0
