Longitudinal Waves in Air (Experimentally determining the speed of sound)
The discussion revolves around an experiment conducted to determine the speed of sound in air using a vibrating column of air and a tuning fork. The original poster presents equations relating to the resonance conditions and speed of sound, questioning the equivalence of two different formulas for calculating speed based on the length of the air column.
  • The original poster attempts to understand the mathematical equivalence of two formulas for the speed of sound, while others question the applicability of one formula to the experimental setup involving a pipe with one open end.
Participants are exploring the implications of the formulas presented and discussing their relevance to the specific experimental conditions. Some guidance has been offered regarding the nature of the formulas and their corresponding setups, but there is no explicit consensus on the interpretation of the equations.
There is an ongoing discussion about the assumptions related to the type of ends of the pipe and how they affect the formulas used for calculating the speed of sound. The original poster notes that one formula does not yield a result when n=1, which raises further questions about its applicability.
Von Neumann
Problem:
In my physics class, we conducted an experiment involving a column of air set vibrating by a tuning fork of a known frequency f held at the upper end. The wave travels from the source to a fixed end (namely the water in the lower end of the tube) & reflected back to the source.
Assuming it takes a half-integral number of periods,
(n-1/2)T=(n-1/2)/f
for the wave to return to the source, then the compressional wave sent from the tuning fork in its downward motion and reflected by the water will arrive back at the fork just in time to aid its upward motion. Since there is no phase change in the compressional wave reflected off of the water, the condition for resonance is
(n-1/2)/f=2l/v
where n is a positive integer, and l is the length of the column of air, and v is the speed of the wave (the speed of sound). Solving for v,
v=2lf/(n-1/2)
We then compare the results of the experimentally determine v to the theoretically calculated v using the formula
v=[itex]\sqrt{\frac{(\gamma)RT}{M}}[/itex]
Where [itex]\gamma[/itex] is the thermodynamic constant for air, R is the universal gas constant, T is the absolute temperature, and M is the average molecular weight of air.
However, an alternate formula for v in terms of the distance l' from the first node to the bottom of the air column is
v=2l'f/(n-1)
This formula is given with no explanation, and I am wondering if it is mathematically equivalent to the other experimental formula for v. It is obvious that this particular formula will not yield a result when n=1.
The last formula corresponds to two open (or two closed) ends.
If you wouldn't mind, can you elaborate on why this is the case?
With a closed end, you get pressure differences a both sides, so you should match a wave of high pressure from one end, traveling 2l through the pipe, with the next (or next to next, or ...) time of high pressure. This gives an integer multiple of wavelengths in 2l.
You can drop the -1 if you like.
If, as you claim, the equation v=2l'f/(n-1) correlates to the situation involving a pipe with 2 open or 2 closed ends, then it certainly has no relevance in this experiment having to do with a pipe with 1 open end. Correct?
Anyone have any HELPFUL suggestions?
Correct
I am not sure how to interpret that post...
