Equation of an ellipse given c and eccentricity.
The discussion revolves around finding the equation of an ellipse given specific parameters: a center at (0, 0), a horizontal major axis, an eccentricity of 1/2, and the condition that 2c = 1.
  • Participants explore the relationship between the parameters c, a, and b, with some questioning the definition of c. There are attempts to apply the equation relating a, b, and c for ellipses, and discussions about the implications of the eccentricity on these parameters.
Some participants have provided calculations and suggested relationships between the variables, while others are checking the accuracy of the expressions used. There is ongoing exploration of the correct form of the ellipse equation, but no consensus has been reached on the final equation.
There is some ambiguity regarding the definition of the parameter c and its implications for the values of a and b. The discussion reflects the constraints of the problem as posed in a homework context.
bnosam
Write the equation of the conic that meets the conditions:
An ellipse that has the centre at (0, 0), has a horizontal major axis, the eccentricity is 1/2 and 2c = 1.
[tex]\frac{(x - h)^2} {a^2} + \frac{(y - k)^2}{b^2} = 1[/tex]
2c = 1, [tex]c = \frac{1}{2}[/tex]
e = c/a, so .5/1 = 1/2 [tex]\frac{(x)^2} {1^2} + \frac{(y)^2}{b^2} = 1[/tex]
Not quite sure to go from here
It's not clear what the parameter c is, but the eccentricity can also be defined in terms of a and b, the lengths of the semi-major and semi-minor axes.
Use ##a^2=b^2+c^2## for an ellipse.
Since ## 2c = 1 ##, then ##c = .5 ##
Making the variable ##a = 1##
##e = 1/2 = .5 / 1##
## (1)^2 = b^2 + (.5)^2 ##
## 1 - .25 = b^2 ##
## b^2 = 3/4 ##
So this would set the answer to:
## x^2 + \frac{3(y^2)}{4} = 1 ##
Correct?
## 1 - .25 = b^2 ##
## b^2 = 3/4 ##
Correct?
Check your ##\frac{y^2}{b^2}##.
Oops
## x^2 + \frac{4(y^2)}{3} = 1 ##
Thanks a million :)
