Thermal stress of two peices of metal attacthed to two plates.
The problem involves a brass tube and a steel rod, both attached to end plates, experiencing a temperature increase of 58°C. The respective thermal expansion coefficients and Young's moduli for brass and steel are provided. The goal is to determine the resulting stresses in both materials, considering tension as positive and compression as negative. The equation ΔL/L=(σ/E)+alpha(ΔT) is used, but the user struggles with the presence of sigma on both sides of the equation. The distance between the plates is expected to change due to the temperature increase, leading to a new distance L.
larz19943
2)Both, a brass tube and the steel rod located inside the brass tube are solidly attached to common end plates A and B at either end.
The respective diameters are :
Do = 5.4 [cm]
Di = 3.0 [cm]
d= 2.8[cm]
Brass:
alpha=19x10^-6/degree celcius
E=210GPa
Steel:
alpha=12x10^-6/degree celcius
E=105GPa
Initially the assembly is stress free.
Now the temperature increases simultaneously for the brass tube and steel rod by 58oC. As a result the distance L between the two end plates will change.
Determine the resulting stresses in the brass tube and the steel rod, counting tension as positive and compression as negative.
Following Questions to be answered:
Stress in Brass in MPa
Stress in Steel in MPa
I solved for L in the equation above since the length is the same. then I pluged the know values in them but now I have a sigma on both sides and that is what I need to find out and I can't figure out how to solve it.
It's not clear, but is the distance between the plates supposed to remain constant after the temperature change?
Yes but that distance is not given, the plates move a distance delta L apart after the tempature change.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
