OpenFTA radio buttons invisible in defining Primary Event
  • Thread starter Thread starter FizicistsRool
    Invisible Radio
The discussion addresses the visibility issue of radio buttons in the OpenFTA application when defining a "Primary Event" on Windows 7 64-bit. Users experience a message indicating incompatibility with the Windows Aero Theme, which leads to the application switching to Windows 7 Basic. The identified solution is to change the theme to Windows Classic, although this workaround may cause the main fault tree window to become blank. Users are encouraged to ensure the main window has focus when switching themes to mitigate this issue.
  • Familiarity with OpenFTA application functionalities
  • Understanding of Windows 7 theme settings and their impact on applications
  • Basic troubleshooting skills for software compatibility issues
  • Knowledge of Fault Tree Analysis concepts
  • Research OpenFTA user guides for troubleshooting visual issues
  • Explore Windows 7 theme settings and their effects on application performance
  • Investigate alternative themes or settings that enhance compatibility with OpenFTA
  • Learn about Fault Tree Analysis best practices and software requirements
This discussion is beneficial for software testers, fault tree analysts, and users of OpenFTA who are experiencing visual compatibility issues on Windows 7.
FizicistsRool
I am test driving an app (OpenFTA, http://www.openfta.com) for small Fault Tree Analyses on Windows 7 64-bit. In one of the functions (defining a "Primary Event"), the radio buttons are not visible. Googling with the following search phrase does not yield anything relevant:
open-fta primary-event radio-buttons-not-visible
I'm not sure if OpenFTA is malfunctioning or whether this is due to the fact that Windows 7 changes the colour scheme when the app is run. I always get a temporary message:
"The color scheme has been changed to Windows 7 Basic. A running program isn't compatible with certain visual elements of Windows."
Clicking on the message indicates that the app is incompatible with Windows Aero Theme. A comparison between Aero and Basic shows that the primary visual difference is the lack of translucency in Basic. I suspect that this would not cause the radio buttons to be invisible because the app is not meant to use Aero features anyway.
1. Has anyone else used OpenFTA on Windows 7/Vista and either encountered this problem or NOT encountered this problem?
2. What could be the cause?
3. What are workarounds or solutions?
Thanks.
I found the solution. Change from Windows 7 Basic theme to Windows Classic theme at Control Panel\All Control Panel Items\Personalization.
Afternote: Actually, it's a pretty nonideal solution. It works for defining Primary Events, but the main fault tree window sometimes becomes blank when the "solution" is in effect. So far, I could avoid this by ensuring that the main fault tree window has the focus when switching to Windows Classic theme.
  • · Replies 16 ·
10K
