Generating elctricity from earths magnetic field
Generating electricity from Earth's magnetic field is not feasible due to two primary reasons: the Earth's magnetic field is relatively static and low in strength compared to commercially available permanent magnets. While large coronal mass ejections from the sun can cause significant variations in the magnetic field, leading to large currents in power transmission lines, these events are not reliable for consistent electricity generation. Historical events, such as the March 1989 incident that affected Canada and the NE USA, illustrate the impact of solar flares on electrical systems but do not support the viability of using Earth's magnetic field for power generation.
  • Understanding of Earth's magnetic field dynamics
  • Knowledge of electromagnetic induction principles
  • Familiarity with coronal mass ejections and their effects
  • Basic concepts of electrical engineering and power transmission systems
  • Research the principles of electromagnetic induction and its applications
  • Study the effects of coronal mass ejections on electrical infrastructure
  • Explore alternative renewable energy sources and their feasibility
  • Investigate the strength and applications of permanent magnets in energy generation
Researchers in renewable energy, electrical engineers, and anyone interested in the interaction between solar activity and electrical systems will benefit from this discussion.
unclebob
Q: Is it possible to generate electricity by locating a coil at one of Earth's magnetic poles? By grounding to the Earth a lead out to a load. Maybe Earth's rotation and the coil at some elevation just off the center of magnetic flux lines entering the earth. Would this cause flux lines to cross the coil?
no not really
2 main reasons
1) the Earth's magnetic field is relatively static, unless it comes under outside influence
ie. coronal mass ejections etc from the sun
2) the Earth's magnetic field is quite low in strength compared to any of the reasonable permanent magnets you can buy
Large coronal mass ejections from the sun can cause quite large variences in the magnetic field and these can cause large currents to flow in long distance power transmission lines oil pipe lines etc.
It was these large current flows that tripped out protection circuits across Canada and the NE USA during March 1989, after some of the largest solar flares and assoc. CME's ever recorded.
Dave
  • · Replies 26 ·
9K
