Projectile Motion - What angle should the quarterback throw the football?
The problem involves projectile motion, specifically determining the angle at which a quarterback should throw a football to reach a receiver a certain distance away. The quarterback throws the ball at a speed of 22.0 m/s to a receiver located 31.0 m away, with the assumption that the ball is caught at the same height from which it is thrown.
  • The original poster attempts to calculate the time of flight and vertical velocity but encounters difficulties with the calculations and the use of trigonometric functions. Other participants suggest treating the horizontal and vertical motions separately and question which equations are appropriate for finding the vertical component of the motion.
Participants are actively discussing different approaches to solving the problem, including separating the horizontal and vertical motions and identifying the correct equations to use. There is a focus on clarifying the steps needed to find the time of flight and the vertical velocity, but no consensus has been reached on a specific method or solution.
The original poster expresses frustration with the calculations and seeks guidance on the steps to take, indicating a potential lack of understanding of the underlying concepts of projectile motion.
ElleElle
A quarterback wants to throw a football at 22.0 m/s to a receiver 31.0 m away. At what angle above the horizontal should he throw it? Assume that the receiver catches the ball at the same height that the quarterback releases it.
The answer should be 19.4° but for some reason I just cannot get it!
Please help me with the steps!
I solved for time by using: x = xi + vit + (1/2)at^2
I got t = 1.13s
Then i used x = vt to solve for velocity in the y direction. vy = 27.5 m/s (which does not seem right)
Then cos θ = adj/hyp which gives me a math error :/
Treat the horizontal and vertical motions of the ball separately. To find the time, find the vertical component of the ball's velocity, and see how long it will take for the ball to reach its maximum height and come back down.
tms said:
Treat the horizontal and vertical motions of the ball separately. To find the time, find the vertical component of the ball's velocity, and see how long ti will take for the ball to reach its maximum height and come back down.
What formula would i use for the vertical component? Vf=Vi+at and Δy=Vit+(1/2)at^2 ?
Which do you think? You know, or can calculate, the initial vertical speed, you know the speed at the maximum height, you know the acceleration, and you want to find the time. Which equation will give you what you want knowing what you know?
Try this: Find an equation that gives you the time it takes to go up and down. Then find another equation that gives you the time it takes to get there in the horizontal direction. Hint: You are already given what x is. You will have two unknowns with two equations. Solve for target!
Your also going to need a trigonometry identity.
