Equation for speed of charges (electrostatics)?
The discussion revolves around a problem in electrostatics involving two charged particles with different masses and charges. The original poster seeks to find the speed of each particle as they approach each other, specifically when their distance decreases from 1 meter to 0.5 meters.
  • Participants discuss the lack of a direct equation linking speed and charge, while suggesting that existing equations relate charge to force, force to acceleration, and acceleration to speed. There is an exploration of using Coulomb's law to determine force and subsequently acceleration, but concerns arise regarding the non-constant nature of acceleration as the distance changes.
The discussion is active, with participants questioning the assumptions about acceleration being constant and exploring the implications of varying forces on the particles. Some suggest considering conservation laws as a potential approach to the problem.
Participants note the challenge of determining individual distances traveled by each particle, given that only the total distance is provided. The problem is framed within the constraints of the exercise, which may limit the available information for a straightforward solution.
devil0150
I am trying to do an exercise but there's no equation in the book that links speed and charges. Can anyone help? This is the exercise:
There is a particle with mass = 20 grams and charge = 6 x 10^(-6) C, and another particle with mass = 50 grams and charge = -4 x 10^(-6) C. The distance between the particles is 1 m. Find the speed of each particle when their distance becomes 0.5 m.
Not directly, but I'm sure you have equations that relate charge and distance to force, force and mass to acceleration, acceleration and distance to speed.
Yes I tried using coulomb's law to find the force, and then each of the accelerations (a = F/m) but to find the speed from this (v^2 = 2*a*d) I need the individual distance traveled by each particle, and I only have the sum of both distances (0.5 m).
Edit: And since the force has different value for different positions of the particles, doesn't that mean that the acceleration isn't constant? How can I find the speed using a non-constant acceleration?
In such cases it's often profitable to consider the problem in terms of conservation laws :wink:
