| Thread Closed |
Calculating Net Work |
Share Thread | Thread Tools |
| Mar11-05, 04:24 PM | #1 |
A 391 kg piano slides 3.7 m down a(n) 27° incline and is kept from accelerating by a man who is pushing back on it parallel to the incline (Fig. 7-23). The effective coefficient of kinetic friction is 0.40.
Figure 7-23 (a) Calculate the force exerted by the man. 374N (b) Calculate the work done by the man on the piano. -1384J (c) Calculate the work done by the friction force. -5054J (d) Calculate the work done by the force of gravity. 6438J (e) Calculate the net work done on the piano. _____J I got the previous questions correct with the exception of letter "e". This is what I did... WORKnet = Wgravity-Wfriction+Wnormal force in x direction-Work man in x direction My numbers were 6438-5054+6437-1384 = 6437J The problem must be in the way I'm calculating the normal force in the x direction. I used Fn=Fg*sin27*3.7m=6437J Thanks in advance for the help. |
| Mar11-05, 06:06 PM | #2 |
Mentor
A shortcut way to get the net work on an object: The net work equals the change in KE. |
| Mar11-05, 06:18 PM | #3 |
so I should simply be able to omit the WORKnormalforce component and get the answer....but its still wrong. Since there is no velocity given, and there is no accleration or time, then it has a KE of 0, right?
Maybe I can use the change in potential energy? I can find the length of all sides since the 27degree angle is given and the distance 3.7 is given. Find the mgh at the max height, then find the mgh at the min height. Will the difference be the -Work ? |
| Mar11-05, 07:03 PM | #4 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: Calculating Net Work
| Calculating Work | Calculus | 0 | ||
| Calculating Work | Introductory Physics Homework | 1 | ||
| calculating work done by friction | Introductory Physics Homework | 3 | ||
| Calculating Work | Advanced Physics Homework | 3 | ||
| Calculating the work done by friction | Introductory Physics Homework | 11 | ||
