Physics Postlab Help - Get Answers to Questions
  • Thread starter Thread starter Habibrobert
    Lab
The discussion revolves around a physics postlab involving a cart on a frictionless track connected to a weight via a string. Participants express skepticism about the accuracy of their answers and the potential for the problems to be misleading, particularly regarding values derived from a graph.
  • Participants question the measurement of force and the method used to determine the mass of the hanger. There are discussions about the role of the force sensor and the interpretation of its readings, particularly in relation to tension and acceleration.
Some guidance has been offered regarding the measurement of force and the potential issues with the mass calculation. Participants are exploring different interpretations of the setup and the readings from the force sensor, indicating a productive exchange of ideas without reaching a consensus.
There is mention of specific values being tricky and the need for clarity on the measurements taken, particularly concerning the force sensor's readings and the assumptions about acceleration.
Habibrobert
Hello everyone, I'm working on a physics postlab due tomorrow, and I'm just really skeptical that the answers I am getting so far are correct, I just feel like the problems are designed to "trick you" because of the values you are looking for are on the graph. could you guys please take a look at it and tell me how to do this particular page of the prelab correctly? The set up is a cart on a frictionless track that has a string tied to it which is also tied to some weight (the prelab calls it a hanger) that is hanging down and pulling on the cart. Attached a screen shot of the prelab
Thanks very much!
Check the decimal point for the force.
Where is that force measured?
How did you get the mass of the hanger?
The force is measured from the car, before and after it was released. I used F=m*a to find the mass of the hanger, but I feel like that is wrong.
In other words, it is the tension of the string connecting both?
It is hard to tell if you don't add which a and F you used. The mass looks wrong.
Is the force sensor mounted on the cart and the string tied to the force sensor?
  • acceleration ok.
  • Decimal point in force on force sensor while accelrating wrong. I am not sure if they want the negative though. All it means is that the force sensor is registering a pull , which is displayed as a negative value. A push on the sensor will be displayed as a positive value.
  • Mass of the hanger wrong. The force sensor reads the (full) tension in the string when the cart is stationary.
  • · Replies 47 ·
9K
  • · Replies 30 ·
