Find magnitude of acceleration on a Ca ion, given electric field.
The discussion revolves around calculating the magnitude of acceleration for a Ca2+ ion in an electric field of strength 107 N/C. Participants are exploring the relationship between force, charge, and acceleration, while considering the mass of the ion.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of force using the charge of the ion and the electric field, questioning whether to use the charge of one proton. There are attempts to clarify the mass of the calcium atom and its relation to atomic mass units.
Some participants have provided guidance on the correct charge to use in calculations. There is an ongoing exploration of the mass of the calcium atom and its implications for the acceleration calculation. Multiple interpretations of the problem are being discussed, but no explicit consensus has been reached.
Participants are working under the assumption that resistive forces can be ignored and are referencing atomic mass units in their calculations. There is also a mention of an online homework assignment that may influence the discussion.
monnapomona
The electric field strength across a typical cell membrane is about 107 N/C. Given this information, find the magnitude of the acceleration of a single charged Ca+1 ion as it penetrated through the cell wall. Ignore any resistive forces.
One atomic mass unit is 1.66 x 10-27 kg.
F = ma
F=q0E
I was thinking of multiplying the charge with how many protons a Ca ion has so:
F=q0E
= (20[itex]\bullet[/itex]1.6*10-19C)(107 N/C)
= 3.2*10-11 N
Then I manipulated for acceleration in F=ma and got 1.93*1016 m/s?
Is this the correct method for finding the magnitude of acceleration?
Ca1+ means that the charge on the ion is only unbalanced by ONE proton charge. I.e. the atom has lost one electron, leaving it with a net positive charge due to ONE extra proton whose charge is unbalanced.
So would it be correct if I just use q=+1.6*10-19 C in the formula to find force?
Yes.
cepheid said:
Yes.
Okay so I used q=+1.6*10-19 C in the formula and got F = 1.6*10-12 N. To find the magnitude of acceleration, I manipulated for a in F = ma and got 9.64 * 1014 m/s as the answer but I inputted it in my online homework assignment and apparently it's wrong.
Should I use a different formula to find acceleration?
Edit: I used 1.66*10-27 kg as the mass.
That's one atomic mass unit. How many of those per calcium atom?
To get atomic mass, do I need to add protons and neutrons in Calcium together? So 40?
Sounds about right to me.
Sweet, I got the answer right! (2.41*1013 m/s) Thanks for all your help everyone! :D
9K
  • · Replies 16 ·
