Calculating Contact, Weight & Frictional Forces on a Moving Platform
  • Thread starter Thread starter PhysicsIdiot
The discussion revolves around calculating contact, weight, and frictional forces on a horizontal platform that is moving with constant acceleration. Participants are exploring the implications of mass interactions and the effects of acceleration on force readings.
  • Mixed
  • Participants are attempting to calculate contact forces between two masses and question whether to consider both masses or just one in their calculations. There is also discussion about the weight reading on a scale and how it is affected by the position of the scale relative to the masses.
  • Questions arise regarding the direction of forces exerted by the masses on each other, with some participants clarifying their understanding of these interactions.
  • Frictional forces are being analyzed in relation to the acceleration of the platform and the coefficient of static friction, with some participants expressing uncertainty about how these factors interrelate.
  • There is exploration of how the angle of acceleration might affect the calculations, particularly in relation to the scale's reading.
The discussion is ongoing, with participants providing insights and clarifications on the forces involved. Some have suggested that the acceleration affects the scale's reading, while others are still grappling with the implications of the angle of acceleration on the various forces at play. There is no explicit consensus, but several productive lines of reasoning are being explored.
Participants are working under the assumption that the platform, scale, and objects are made of the same material, which influences the coefficient of static friction. The exact positioning of the scale is also a point of contention, affecting the calculations being discussed.
PhysicsIdiot
http://img213.exs.cx/img213/852/sita2ju.jpg
Look at the link above for reference (sorry, I am not very skilled at paint)
It's on a horizontal platform moving with a constant acceleration.
Question 1: Calculate the contact forces between objects 1 and 2.
My Answer: It's a simple F=mg, surface area doesn't matter with forces, only pressure does. But do i use both masses or just mass1? (the force of mass1 ON mass2) :frown:
Question 2: Calculate the weight that would show on the scale.
My Answer: W = (m1 + m2)g
Question 3: Calculate the frictional forces assuming that the platform, scale and objects 1 and 2 are made out of the same material of coefficient of static friction "mew sub s".
My Answer: I'm still working this one out so any help would be greatly appreciated. :approve: I'm just writing/drawing out the forces on each object; haven't come to anything definite yet.
m1 exerts a force of m1g on m2. m2 exerts an upward force on m1 equal to m1g because m1 does not accelerate in the vertical direction.
I can't tell where the scale is. Is it under m2? If so, you are right.
The frictional force is a function of acceleration and the masses m1 and m2. It does not depend on [itex]\mu_s[/itex]. [itex]\mu_smg[/itex] determines the maximum frictional force that the surfaces can provide but they only provide that when a force of that magnitude is applied to the masses.
AM
Isn't that the other way around? m2 exerts a force (down) of (m2)g on m1 and m1 exerts the same (up) onto m2? And does m1 exert a force of (m1)g up on m2 or does it exert a force equal to m2's force (i.e. m2 * g)
yeah, it's right under m2.
AM
Sooo... it's F= ma ; F = f(friction) ; ma = f
So frictional force of m2 on m1 is just (m1 * g)?
And frictional force of m1 on the platform is (m1 + m2)g?
Also, the platform is accelerating at that angle? It doesn't matter because it's constant right?
Sorry for the confusion. I had m1 and m2 mixed up in my mind. I was thinking of m2 on the bottom.
I meant m1. If it is between the floor and m1, then the scale reads m1g + m2g.
Right. That is the force that m2 applies to m1. This is because the only force that is acting on m1 is this friction force and m1's acceleration is a. Therefore, [itex]F_f = m1a[/itex]
Correct. The friction force of the platform on m1 (and of m1 on the platform) is (m1 + m2)g.
I am not sure what angle you mean. It is accelerating along the direction of the x axis.
AM
AM
If you look at the picture, the platform is accelerating at an angle (not straight, otherwise the arrow would be straight) (look at the bottom right)
Thanks for all the help :biggrin:
wouldnt it be: m1 + m2 (g + Asin"theta")? my friend said he got that.. i don't know
"A" being the magnitude of the acceleration
this is for question # 2
Acceleration is in the x direction only. The angle is 0.
AM
AM
i guess my drawing was off so i made a nother picture; the acceleration is done at an angle:
http://img37.exs.cx/img37/3628/sitb0yi.jpg
However, it's constant so would it matter for question #2 (or any of the other questions for that matter)?
Anyone?
Bump, I am still stuck on this.
If the scale (and entire system) is accelerating at an angle then the scale will read (m1+m2)*g+(m1+m2)*g*sin(theta). Only the y-component of the acceleration is affecting the scale's reading, because with acceleration comes force. Since the system is being accelerated there is an extra force on the scale (equal to (m1+m2)*g*sin(theta). ).
Think about standing on a scale in an elevator, as the elevator accelerates upwards, your scale will read a higher weight than when it is not accelerating. Accordingly, a lower weight as it accelerates downwards.
does this acceleration affect questions 1 and 3?
I'm not sure but I believe so, each mass acts as a scale to all other objects it is contacting, so a larger force on the entire system equates to a larger force on each object, so the forces between the objects will increase.
  • · Replies 40 ·
