What is the force applied to a moving object?
  • Thread starter Thread starter Robertoalva
    Forces
The discussion focuses on calculating the force applied to a 1-kg object moving in the x direction, initially at 17.1 m/s and later at 30.9 m/s at an angle of 30.3° after 3.75 seconds. To solve this problem, participants emphasize breaking down the force into x and y components, applying Newton's second law (F=ma), and determining the change in velocity in both directions. A visual representation of the object's velocity vectors at the two time points is recommended to aid in understanding the problem.
  • Understanding of Newton's Laws of Motion
  • Basic knowledge of vector decomposition
  • Familiarity with kinematic equations
  • Ability to calculate acceleration from velocity changes
  • Learn how to decompose vectors into x and y components
  • Study the application of Newton's second law (F=ma) in two dimensions
  • Explore kinematic equations for motion in a plane
  • Practice problems involving force calculations in physics
Students studying physics, particularly those focusing on mechanics and forces, as well as educators seeking to enhance their teaching methods in kinematics.
Robertoalva
A 1-kg object is moving in the x direction at 17.1 m/s. Just 3.75 s later, it is moving at 30.9 m/s at 30.3° to the x axis. What are the magnitude and direction of the force applied during this time?
F=ma
I have no idea on how to do this problem!
Try approaching the problem by considering the force in the x and y directions separately. That's usually a good first approach in anything related to Newton's Laws or kinematics in my opinion.
If you can find the change in velocity in the x and y direction, you can then find the acceleration in the two directions, which would give you the force applied.
A more useful thread title and more effort on your part to attempt the problem would help you in the long run.
Assume that the object is moving in the x-y (horizontal plane). Draw a picture (qualitative) showing the object location and velocity vector at times t = 0, and t = 3.75 s. What are the x- and y components of the object's velocity at time t = 0, and t = 3.75 s? This should give you some idea of what to do next.
  • · Replies 41 ·
  • · Replies 21 ·
